distributorless ignition for a TPI
Old Jul 23, 2004 | 09:53 PM
TA Dreaming's Avatar
Just wondering if it is possible to run a distributorless ignition system on a TPI motor? Is there a kit or product availible to make this happen? Just thinking out loud really. Any info is appreciated. Thanks.
Old Jul 24, 2004 | 02:58 AM
Zepher's Avatar
Re: distributorless ignition for a TPI
Electromotive TEC-3 will eliminate the distributor and run a Cam or Crank (can't remember which) Position sensor and coil packs. $2300 for the complete system with harness, ECM, and related accessories.
Old Jul 25, 2004 | 10:04 AM
FruityOne's Avatar
Just a little oh the high side for that system! I hope the ECM is on par with the latest DFI setup for tunability.
Old Jul 25, 2004 | 02:18 PM
Zepher's Avatar
It is one of the best ECMs for tuning. I am going to get this setup in a year or two. Can't afford it right now.
Old Jul 25, 2004 | 04:47 PM
FruityOne's Avatar
I think I'll stick with my stock ECM for now. Thats one expensive setup. Though I suppose its not much more expensive than any current DFI setup either.
Old Jul 25, 2004 | 10:43 PM
aklim's Avatar
If you really had to go DIS, why not just go for an LT1 complete with harness?
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
