Demon Carb + Kickdown cable. Geometry Help needed.
Old Mar 12, 2004 | 11:29 PM
AutoRoc's Avatar
As far as using a kickdown cable for a 700R4, what is the correct way to do it? B&M makes a bracket that you're supposed to use and I have it, just not sure if I'll use it yet, I think other shifter companies make one also but which is best? Are people getting away with using the normal Holley/Demon throttle bracket? I've talked to Dana at Pro Built about it a while back and he explained the proper throttle geometry numbers and spacing and this points to that etc but obviously I need new information. Thanks!
Old Mar 13, 2004 | 05:15 AM
greezemonkey's Avatar
This is the S***!
this is the best way to hook that a-4 to your demon, plain and simple! Where you at in michigan?
http://www.tvmadeez.com/Demon_cam/index.html
Old Mar 13, 2004 | 11:25 AM
AutoRoc's Avatar
Downriver area! Thanks! I'll look into that, hopefully I can just use this B&M bracket tho. hehe
Novo
Jun 14, 2016 02:58 AM
HibachiZ28
Nov 6, 2015 12:53 AM
Kawi
Sep 28, 2015 09:01 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
