dead battery?
Old Jul 18, 2003 | 03:57 PM
CamaroZ28Coupe's Avatar
dead battery?
i was cleaning my car the other night and i guess i must have left the lights on inside because today i went inside the car and had zero power. will a batery recharger work or is the battery shot. i heard that once a battery completely drains its toast. is that true? what should i do?
Old Jul 18, 2003 | 04:02 PM
Slow91z's Avatar
Charge it and see if it will hold a charge...Best way to do that is charge it up fully and take it to autozone and they will test it for you, but make sure it's charged before you take up there or they will tell you you have a bad batt, when it's only not charged.
Old Jul 18, 2003 | 04:03 PM
Pro
Guest
Posts: n/a
It might be ok. I have done it twice, and both times I jumped it off, and then let the alternator charge it.
DONT DO THIS LIKE ME AS A FOOL. Your alternator will hate you. I went through 2 of them before I finally realized. Let a charger charge it up as high as it can.
Old Jul 18, 2003 | 04:10 PM
Slow91z's Avatar
For real
Old Jul 18, 2003 | 07:14 PM
TheGreatJ's Avatar
Yeah...that's a real good way to fry an alternator. Break out the charger, and disconnect the battery before you charge it up. Set it to the lowest charge rate and let it go for a few hours. That'll give you the best chance of saving it.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
jackpawt883
Sep 10, 2015 08:53 PM
