cutout question
Old Mar 7, 2003 | 07:55 PM
camarocruzin's Avatar
cutout question
I'm planning on begging the exhaust upgrades for my 89' Iroc. I've been doin reading and going through these boards and decided on the Hooker Cat-back and The Edelbrock TES headers system. I was going to not run a cat, and had a few questions. First What is the purpose of the air tube running down to the cat, and what should i do with it if running no cat? Next could I put a slip on y cutout and some 3" pipe in place of the cat, to both fill in length of the missing cat and allow me to open up the exhaust if i ever get to the track? I want a setup that would allow me to run like this, but easily bolt a cat in when i get called in for emissions. Any comments, suggestions, or help we be great, thanks
Josh
Old Mar 8, 2003 | 01:12 AM
stonedchihuahua's Avatar
be creative... thats about all i can tell you
Old Mar 8, 2003 | 03:31 AM
Aaron91RS's Avatar
Put the cutout in front of the cat. Then you don't have to worry about the cat at all.
Old Mar 8, 2003 | 07:23 AM
IROC5.7TPI's Avatar
cutouts suck on anything slower than a 13 second car. They are a waste of time and sound like @ss.
I have one and thats my opinion of them.
Old Mar 8, 2003 | 01:41 PM
thanks for the comments, im still confused about the tube that runs to the cat and what to do with it if i do go without a cat though
Old Mar 8, 2003 | 04:29 PM
mr diabolical's Avatar
just run/weld the air pipe into your new exaust or weld it shut. or completely take it off if you dont want it on your car. it wont hurt a thing no matter what you do with it. mines been gone for years
i run a cutout before and after the cat. with it open before the cat you can hear more engine fire(popping kind of noise). the one after the cat has a more of a tone than before the cat. it sounds great. i wouldnt do the before the cat unless for the track. i run the after the cat one on the street.
Old Mar 8, 2003 | 10:10 PM
stevem's Avatar
dont pinch the air pipe off it will cause a noise in your air pump.
either take it out or weld it in.if you are going to keep your cat you need it to help emissions.it will pump air into the secondary bed and cause it to heat up to get rid of emissions.
Old Mar 9, 2003 | 02:12 AM
stanghunter211's Avatar
Cutouts are awesome and they Do Not sound like ****...... Lowered my time by .3 in the 1/4, not bad for 45 bucks installed..... And that was with a plugged cat. I have not run it with the !cat
Will
Old Mar 9, 2003 | 06:21 AM
IROC5.7TPI's Avatar
Will
So wouldn't it make sense to say that BYPASSING a clogged cat with a cutout was worth the .3's? The cutout wasn't responsible for the improvement as much as the clogged cat was killing performance.
Old Mar 9, 2003 | 12:01 PM
I don't have a cat anyway, and in Cali its illegal to place it before the cat, regardless. My car still passes the sniffer with a hollow cat, so as long as they see one there, with nothing infront of it, its passes. Do you have some kind of grudge against cheap performance or what? Just cuz you don't like a cutout doesn't mean this guy won't.
I meant this as an example, that it infact helped over the the exhaust exiting the muffler. I've got time slips to prove it, so if it helps with a ****tty stock catback, then it must help with a better performing system. All the guys I know out here run cutouts, there MUST be something positive about it right?
Later
Old Mar 9, 2003 | 01:37 PM
TunedPort 335's Avatar
Here's where I mounted mine -
my cutout
BTW....cutouts sound good on built cars, not stock ones.
Old Mar 9, 2003 | 01:40 PM
And my Cutout is mounted AFTER the cat, under the rear seats, so YES it was responsible for the .3 drop. By bypassing the muffler, it dropped significantly.
Old Mar 9, 2003 | 08:00 PM
Thanks guys, im only going to be running the cutout at the track so the sound really won't matter i just want little better flow for a slightly more respectable timeslip
birdblack
Exhaust System
Jan 4, 2015 09:41 PM
lbrowne
Nov 13, 2011 04:25 PM
Chrisdude
Jul 24, 2002 02:25 PM
Camaro90RS
Jul 23, 2002 07:57 AM
