cold cranking
Old Jan 22, 2005 | 10:25 PM
rat-at-tach's Avatar
cold cranking
my 88 camaro 5l cranks over about 5 or 6 times before fireing in the mornings,the choke and everything is working great im just concerned about the amount of cranks it takes to fire.
Old Jan 22, 2005 | 11:16 PM
IROC-T's Avatar
Re: cold cranking
My '88 does the same thing when it's cool outside,with the first start up in the morning,don't know if there is anything wrong it's always been that way since new,but now I'm living in a warmer climate it starts right up even after setting for afew weeks.
Old Jan 22, 2005 | 11:22 PM
Nate86's Avatar
Re: cold cranking
My apologies if this seems overly simple, but have you tried pressing down on the accelerator once or twice before trying to crank the engine?
Old Jan 22, 2005 | 11:24 PM
Nate86's Avatar
Re: cold cranking
Whoops, didn't think about the car being an '88. Is it FI or carb? I assumed carb at first because you mentioned the choke.
Old Jan 23, 2005 | 09:33 AM
Re: cold cranking
its a tbi,i shouldnt have to but i put the peddal down just a bit when its cranking.
Old Jan 23, 2005 | 06:42 PM
racecarfan's Avatar
Re: cold cranking
My TBI truck takes a few revs to crank too. Don't know really is there anything wrong. When you first turn the key on you should here the fuel pump kick on. If it doesn't then you may have to crank the engine until the oil pessure switch kicks the fuel pump on. Check your fuel pump relay and make sure your powering up the fuel pump from the get go and not relying on oil pressure switch. hope this helps
Old Feb 1, 2005 | 06:49 PM
wetwillykm89's Avatar
Re: cold cranking
What size engine, some of the 2.8L had a cold start injector in them.
Have you looked at your IAC (idle air control) ?
Old Feb 1, 2005 | 07:13 PM
85_305's Avatar
Re: cold cranking
^ He says in his initial post it is a 5.0
Old Feb 1, 2005 | 08:47 PM
TheGreatJ's Avatar
Re: cold cranking
I've never seen a TBI with a cold-start injector from ANY manufacturer, and I fix cars for a living. In fact, I've never seen a TBI with a choke either.
Try this: when you first turn the key to "run" wait for the pump to shut off. Then turn it off, turn it to "run" again, and start it. If it starts right up your fuel pump is getting weak, if it still takes a few turns then you're probably just looking at wear and tear causing her to take a little longer to get the compression up.
mightymouse383
Jul 20, 2016 07:34 AM
nosliw
Apr 26, 2015 02:13 PM
QuickSilver02
Apr 7, 2015 11:12 AM
greenzee28
Mar 26, 2015 09:13 AM
ModdedNerd
Dec 18, 2014 10:52 PM
