Check Engine Code...
Old Apr 26, 2003 | 01:23 PM
thezisking's Avatar
In my 86 Z, it started to through a check engine code. What pins do you have to jump on the code reader to have it flash the engine code? Thanks!
Old Apr 26, 2003 | 03:09 PM
Error's Avatar
It's the two in the upper right. The connector is under the steering column and slightly to the right. Go to AutoZone. They have the key to trip it with. They gave us one for free.
Once you trip the codes, post em here and I'll let you know what you are.
Old Apr 26, 2003 | 06:25 PM
thezisking's Avatar
It came up code 12.
Old Apr 26, 2003 | 06:30 PM
thezisking's Avatar
I looked it up on a web site and it said it was No reference pulses to Electronic Control Module (ECM)...What does that mean?
Old Apr 26, 2003 | 10:55 PM
krazzycowgirl's Avatar
Code 12 No engine RPM reference pulses--System Normal
Old Apr 27, 2003 | 02:09 AM
thezisking's Avatar
If the system is normal, why is the light on? How do I get it to turn off? I tried reseting the code (Unhooking the battery), but it came right back on? What should I do? Thanks!
Old Apr 27, 2003 | 09:23 PM
slayer6x6's Avatar
http://www.thirdgen.org/faq/thirdgen.shtml#misc this site has a good artice on this topic
Old Apr 27, 2003 | 09:54 PM
Error's Avatar
Try it with the engine running. If you trip it with the motor off, you will ALWAYS get 12. It's how you know the ECM is working.
Old Apr 28, 2003 | 01:13 AM
aklim's Avatar
Could it be that it is getting a short which causes it to light up?
Old Apr 28, 2003 | 01:51 AM
thezisking's Avatar
Could it be because some dumb*** (The guy that owned it before me) removed the smog pump? Isn't that controlled electronicaly?
Old Apr 28, 2003 | 07:42 AM
irocz8957's Avatar
the code blinks 12 times to tell you its ready!
Old Apr 28, 2003 | 10:01 AM
aklim's Avatar
True. However there is no feedback to the ECM from the smog unit.
David Dorris
Jan 17, 2015 08:10 PM
bfmv13trivium
Jan 14, 2015 09:57 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
