Is changing timing on TBI worth it?
Old Apr 27, 2003 | 01:02 PM
SNEAKY NEIL's Avatar
I was thinking about changing the timing on my girlfriend's 90' TBI Formula for a little more power. Is this worth it? As I understand, it will be necessary to run 92 Octane with the new timing. Also, what is the optimum setting? Thanks.
Old Apr 27, 2003 | 05:04 PM
CODY BEHNKE's Avatar
I never had any problems running 2-6 Adv. with 91 octane.
Old Apr 27, 2003 | 05:16 PM
Chuck!'s Avatar
Yea, definitely worth it. I ran 8* advance on 92/93 with no problems.
Old Apr 27, 2003 | 05:24 PM
camaroguy2003's Avatar
I also run 8 degrees and it works great.
Old Apr 28, 2003 | 10:22 AM
dewey316's Avatar
i'm running 6* on 87 octane, and i have no knock problems according the scans i have done with winaldl.
Old Apr 28, 2003 | 11:59 AM
Beast5spdGTA's Avatar
I agree with the rest 6-8*. Total timing stock is less than 20* at WOT, just so you know.
Old Apr 28, 2003 | 01:16 PM
So what is the most you could do and still run 89 octane? Since I do not have a timing light, I will have to bring it to the shop so what will I have to say to them to tell them what I want? Thanks.
Old Apr 28, 2003 | 01:28 PM
Black6SpdTA's Avatar
what kinda gains would i get if i did it? gas mileage go down? when you "advance" your timing does the spark happen earlier and retard= later? thanks
Old Apr 28, 2003 | 01:34 PM
Find a friend that has a timing light, also a small procedure to adj. timing(removing SA wire brown/tan with a black stripe near the heater fan.)
Otherwise,
6 or 8* would be safe IMO. It's gonna depend on other factors. Plugs, carbon deposites, air filter etc. Kinda like adj. tire pressure.
Old Apr 30, 2003 | 06:08 AM
Otherwise,
All that stuff is less than a year old. I think I wil go with 8 degrees advance over stock.
Old Apr 30, 2003 | 07:19 AM
irocz8957's Avatar
i bumped mine up to 10* and it runs great!
Amshnock
14
Jan 18, 2015 11:47 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
