Changing steering gear box
Old May 4, 2007 | 10:02 AM
splinter_cell's Avatar
Im going to be installing a new gear box since the seals on mine are blown and leak fluid. I got one from the classifieds from an Iroc and plan on putting it on this weekend. Anything special I need to know about removing and installing it, like do I need to be worried about aligning anything? I just went out and rented a pitman arm remover, so I got that taken care of.
Old May 4, 2007 | 11:32 AM
Z28SORR's Avatar
No.
Old May 4, 2007 | 02:48 PM
Rice Killer87's Avatar
If you got the pitman arm puller your good to go!
Old May 5, 2007 | 08:31 PM
Stephen 87 IROC's Avatar
The power steering lines need an 18mm wrench. I have a special crowfoot to get at the lines when I need to pull one.
Old May 9, 2007 | 11:12 AM
Anniversary-Z-man's Avatar
Get the pitman arm off...take out the 2 lines and the steering shaft from the box, and unbolt it. Reinstall everything. Just make sure you bleed the fluid though.
D1SC383LT4
Jan 26, 2015 01:41 PM
CaRParts102
Dec 6, 2014 08:45 AM
Jul 4, 2005 05:00 PM
SLIMJIM
Jan 7, 2003 11:06 AM
