Cat question......
Old Aug 16, 2005 | 08:49 AM
86305Z28's Avatar
Cat question......
Lookin to buy a new Cat yadda yadda. Its for an 89 Camaro RS. I was wondering if this cat here would have any problems in terms of clearance from the ground. The Overall Width(in) is 4 so i just wanted to get peoples opinions on if its going to be scraping the ground or not.
My Camaro isnt lowered at all. Its still at the stock height.
Thanks for any info provided and i cant wait to see the concept Camaro
Old Aug 16, 2005 | 01:07 PM
Z28SORR's Avatar
Re: Cat question......
This CAT has a 3/4" larger radius then your standard 2.5" pipe. That means it will stick down 3/4" further than the exhaust pipe. You should be able to tell by looking if this will be a problem or not.
Old Aug 16, 2005 | 09:30 PM
anthony714's Avatar
if the radius is 3/4 larger wouldnt that mean it would hang down half that..say 3/8ths
Old Aug 16, 2005 | 10:25 PM
85_305's Avatar
Looks like a good deal. I would either go with that or a CatCo hi-flow race cat (in which case I did). Only thing is, they are $200 bucks
But also, you might want to round that cat-size up to a 3" or so, as catalytic converters are EXTREMELY restrictive. By going up to a 3", you wont have to worry about it being a kink in your system as much as a 2 1/4 or 2.5 inch convertor
Old Aug 17, 2005 | 09:30 AM
86305Z28's Avatar
what do u mean by it being a "kink in your system"?? just tryin to get a better understanding....
Old Aug 17, 2005 | 11:31 AM
Z28SORR's Avatar
No! That's a 3/4" radius which is a 1 1/2" diameter difference.
Old Aug 17, 2005 | 11:34 AM
Z28SORR's Avatar
You've misread the post. It's a 4" diameter CAT with a 2 1/2" inlet.
Old Aug 17, 2005 | 12:47 PM
85_305's Avatar
What I mean is although you may have a 2.5" exhaust, that 2.5" cat is gonna choke you up simply because cat's do that. So in other words, your whole exhaust is gonna flow nicely; until it hits your cat.
So if you go w/ a cat an inch or so larger than your normal exhaust, you wont have quite as bad as a kink
Nope, I know that. The fact of the matter is the outlet/inlet is *still* only a 2.5". That's gonna choke him up simply because cat's have a tendency to do that.
Old Aug 19, 2005 | 04:00 PM
86305Z28's Avatar
hm didnt know cats did that. good to know for the future. thanks 85.
Old Aug 20, 2005 | 11:23 PM
85_305's Avatar
No problem 86
Old Aug 22, 2005 | 01:57 PM
Tru2Chevy's Avatar
If you need a new cat, just grab a catco or carsound (magnaflow) cat off of ebay for $50.00. The difference in flow from a fancy $200 "race" cat to a standard hi-flow cat is pretty much non-existant.
Getting a cat that has a larger inlet/outlet then the rest of your exhaust tubing would prolly cause more disturbance in flow that it is worth. Ideally you should have a full 3" exhaust.
- Justin
Old Aug 23, 2005 | 07:19 PM
nj85z28's Avatar
i agree with Tru2Chevy
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
