cast hp rating?
Old Jan 2, 2005 | 11:47 PM
jester1's Avatar
cast hp rating?
hi
whats the most power and et that anyone here has seen on the stock bottom end not including piston, just cast rods and crank?
Does anyone here also know anyone running a 20/20 cast crank with serious power?
thanks
Old Jan 3, 2005 | 12:37 AM
92rslt1's Avatar
Re: cast hp rating?
power isnt realy the issue but reliability. i have seen a 10 sec lt1 with a stock bottom end and turbos. however you cant expect it to last. if you try to cheat yourself out of good internals and try to get 600hp out of stock bottom ends your gonna pay in the long run(or maybee short run)
Old Jan 3, 2005 | 07:45 AM
Stephen 87 IROC's Avatar
Re: cast hp rating?
I ran high 11's with a cheap 383. Factory 400 crank, rods, rod bolts. Cast 350 pistons. Heavily ported 2.02/1.60 camel heads. Solid flat tappet cam with around .550 lift. After 2 years it finally threw a rod but I was also shifting at 7000 rpm.
Old Jan 3, 2005 | 06:50 PM
angel71rs's Avatar
Re: cast hp rating?
Originally Posted by Stephen 87 IROC
Factory 400 crank, rods, rod bolts.... finally threw a rod but I was also shifting at 7000 rpm.
You ran factory 400 rods/bolts to 7k!?!
Old Jan 3, 2005 | 08:02 PM
Re: cast hp rating?
The engine was in the car when I bought it. The only thing I did to the engine was get rid of the 76cc smog heads. I got 2 years and about 200 passes on it before it let go. After that I found out the engine was in 2 other cars and had a lot of miles on it. I can't complain about how well it ran and it just goes to show you need need a lot of exotic parts to go fast. The high quaility parts just keep it together longer.
Old Jan 3, 2005 | 09:13 PM
AutoRoc's Avatar
Re: cast hp rating?
9.66 @ 136 with a stock rod/crank 355, 14:1 pistons. Shifting at 8,000rpm with a 2 bolt studded stock 350 block.
Dart 230 Pro 1 heads out of the box, a Super Vic, Dominator, a cam that would make you giggle if you read the specs,th350, Longtubes, 28X10's, 3800+lb raceweight, and a 200 shot fogger setup. Multiple bottles, many many passes and it was torn down before it grenaded.
And then I've seen people scatter rods on low 12 second passes. it's crazy
Old Jan 4, 2005 | 12:32 AM
jester1's Avatar
Re: cast hp rating?
autorock
well make me giggle! If you dont mind me asking how big was the cam approx. if you dont want to give up specs, a ball park to guesstamate, was that also a cast crank?
thanks
LT14LIFE
Nov 15, 2015 06:22 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
karpetcm
Aug 14, 2015 03:02 PM
