carb which one to use
ok guys heres my problem i have a 87 formula with a fresh rebulit 350 it has dart 200cc heads a .490 .510 lift 234 244 dur. cam and an edelbrock rpm intake. Im am currently running a reman edelbrock which works crappy its a 750 too much gas. what carb should i use as a good street carb. thank you
Re: carb which one to use
Is it a QJet or a Carter?
My vote will go for the DEMON 650!!! Even if your engine averages 90% V/E it still will only need a 600 cfm. Bigger is only better if you need it. Low speed torque loss will be the only thing that will happen if you go too big. On the dyno, if it goes into a vacaum under full throttle, that is the only true way too tell if that motor needs more cfm
