Carb metering... help
Old Feb 7, 2004 | 11:43 PM
noc_81's Avatar
I need to do some tuning on my Carter AFB, but I don't know quite how to do it. I basically need to know the air-fuel ratio (rich/lean) and vacuum while driving the car in order to figure out what metering rods and springs I would need. I can't afford to get gauges to mount in the console, but I already have a vacuum gauge.
Also, until then, could I just throw in the old metering rods, springs, and needle seats that were on before I rebuilt the carb with a standard kit? Can I reuse the airhown gasket?
Old Feb 8, 2004 | 10:33 AM
TheGreatJ's Avatar
Go ahead and use the rods/springs/jets that were in there. It'll at least give you a starting point to work with. It's usually possible to re-use the airhorn gaskets on Carter and Edelbrock carbs, since they're above the level of fuel in the bowl anyway, but after the carb's been taken apart a couple times the gasket tends to fall apart.
Check out the carb section at thirdgen.org...there's some good tuning information there for all kinds of carbs.
Kawi
Sep 28, 2015 09:01 AM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
dylan1303
Aug 12, 2015 02:00 AM
bose
Jan 30, 2015 02:36 PM
