Car starts then dies help!
The 305 TBI starts and then dies right away..what should I check? If I start it up and hold the gas pedal down it will cough and stutter, rev up till 3000 rpms, settle down and drive just fine. Seems like it's not getting enough fuel during start up. Kind of sucks that I have to rev it up so high every time for it to start. Any help is appreciated.
Sounds like a vacuum leak under the T/B, spray some carb cleaner arond the base gasket using the red straw on the can. If the idle makes a noticable drop, you've found a leak.
My truck TBI was missing a piece of the T/B gasket an inch wide. It acted the very same way...
fpete1992
Dec 11, 2014 03:51 PM
teedoff59
Aug 8, 2002 01:36 AM
