Car stalls when you put it in gear!
Old Jun 12, 2007 | 05:38 PM
96redhotz's Avatar
Can somebody give me some advice please??? I just rebuilt the 305 in my 88 IROC. It fires up and idles a little high, but as soon as you put it in gear (700R4 by the way) it dies. The only way to keep it running is to drive with both feet. As I gave My IROC to my 16 year old daughter for her birthday, it's a little much for her to master yet. HELP!!
Old Jun 13, 2007 | 06:59 AM
1987IROC350's Avatar
This is usually common with the TPI engines. Its either your tps (throttle position sensor) or a bad chip in your computer. I have had both happen to me.
Are you getting any codes?
Old Jun 13, 2007 | 05:51 PM
96redhotz's Avatar
No, no codes. Before the rebuild, I got codes for voltage but the voltage checks out now.
Old Jun 13, 2007 | 06:11 PM
Tex95Z's Avatar
Hows the IAC? What is your idle set at?
Old Jun 14, 2007 | 05:19 PM
96redhotz's Avatar
was wondering if the IAC could be the problem. The car idles around 1000 to 1100 right now. Throttle shaft seems a little sloppy, too.
ModdedNerd
Dec 18, 2014 10:52 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Joshs99BlackBeauty
Jul 27, 2002 04:22 PM
