can a paxton blower made for 88-92 TPI work on an 87 TPI?
Old Jan 20, 2003 | 09:56 PM
BlowBye's Avatar
Im running V belts not serpentine. Beside converting to serpentine any way that the paxton kit like i said made for 88' up TPI fit my 87' TPI? BTW the only belts im running is waterpump,powersteering,crank and alternator.
Old Jan 20, 2003 | 10:27 PM
wasted420's Avatar
the 87 uses a MAS and i believe the 88 does not
Old Jan 20, 2003 | 10:39 PM
BlowBye's Avatar
What is a MAS? Are your referring to MAF as in Mass Air Flow sensor? Cause its produced from 85-89
Old Jan 20, 2003 | 10:42 PM
wasted420's Avatar
yepp i screwed up ..my bad ..i thought 88 changed ..yeah i was talking about MAF
Old Jan 21, 2003 | 12:40 AM
aziroc's Avatar
88's had speed denisty. not MAF.
Old Jan 21, 2003 | 01:08 AM
Chris Ja's Avatar
Eternal Member
You would have to change from a V belt system to serp belt system.
Old Jan 21, 2003 | 07:06 AM
IROC5.7TPI's Avatar
Sorry but you're wrong. 88's had MAF.
And all you have to change to use the blower is the belt setup.
Old Jan 21, 2003 | 09:28 AM
Osmosis's Avatar
I think it will bolt up, however, you may have to get a special addapter for the MAF. The MAF cars are for 89 and below. 90 and up are speed density. Since it is a 87, it has a different blet system and that may be a problem, but not huge. I'm sure you can omit or even change some things around eailsy.
SpeedJunkee
Jan 27, 2015 10:02 PM
Queens94z28
Dec 20, 2014 09:11 PM
Joes96z
Dec 13, 2014 07:48 PM
Lederman1976
Nov 30, 2014 05:21 AM
