Cam Swap question
Old May 17, 2006 | 01:39 PM
staleyracing's Avatar
Cam Swap question
Im putting a new camshaft in my 92Z28 L98 camaro. Ive done a cam swap on my chevelle while the motor was still in. But, I had a grill to work with and put the cam through. Now, on the camaro there is no grill. After the radiator and condensor are outta the way, is there enough room to slide the cam out of the engine and the new one back in? Or, do I have to take the front facia off the car? Anyone have any luck doing this? Let me know what works please. THanks
Josh
Old May 17, 2006 | 03:23 PM
respectirocz's Avatar
Re: Cam Swap question
the front facia isnt hard to get off
i'm not sure, but i believe you can get the cam out after u remove the radiator and condensor
Old May 18, 2006 | 10:54 AM
iansane's Avatar
I got mine in without even pulling the rad. Just pulled the condensor.
Old May 19, 2006 | 06:53 AM
Do you have to remove the intake manifold or just the distributor? Cause the less I have to remove the better.
Old May 19, 2006 | 07:13 AM
Pneumatic_Tire's Avatar
Intake and distributor has to come off cause you gotta get the lifters out and replace them with any cam swap.
Old May 19, 2006 | 10:01 AM
Its a factory Hyd roller motor..so the lifters are roller/hydraulic stock already. And the cam is a roller/hyd. So, I dont have to put new lifters in do I?
Old May 19, 2006 | 10:12 AM
iansane's Avatar
True, you can keep the stockers.
Old May 19, 2006 | 10:38 AM
Rice Killer87's Avatar
No you dont have to replace them,but you still have to remove them to pull the cam out...which means off comes that PITA TPI.
chuyz28
Jan 15, 2015 04:14 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
cmdeshon
Jan 4, 2015 11:15 AM
Queens94z28
Dec 20, 2014 09:11 PM
chuyz28
Nov 25, 2014 11:14 PM
