C5 transaxle into a 3rd gen?
Old Apr 21, 2003 | 10:01 PM
StealthElephant's Avatar
Anyone do it.....I told me buddy what you said about the rears being completely different and how the C5 rear wouldn't work in a 3rd gen.....he told me anything will fit anything...why do it the easy way when you can custom fab everything....anyone do this....I'm not actually thinking about doing it...but it's something to think about.
Old Apr 22, 2003 | 08:12 AM
Jim85IROC's Avatar
anything is possible with enough money and talent. If you don't have plenty of both, don't waste your time. You'd have to fabricate a completely new rear subframe and rear floor, and probably have to run a fuel cell somewhere inside the car.
You'd have a better chance if you just hung the thirdgen body right over the C5's torque tube complete with front & rear suspension.
Old Apr 23, 2003 | 08:18 PM
TheGreatJ's Avatar
You'd have to move the gas tank...redesign the rear subframe to fit the IRS and transaxle...scrap the back seat and raise the rear floorpan enough to clear the front of the transaxle...come up with some custom linkage work for the shifter if you wanna go 6-speed...custom driveshaft...probably custom half-shafts because I doubt the C5 ones are the right length...wiring work...if you have a cable-driven speedo then you need a cable that's about 5' longer (good luck with that)...
Basically it's just not even remotely close to anywhere near the vicinity of the ballpark of being worth it.
Old Apr 25, 2003 | 12:10 AM
Beast5spdGTA's Avatar
In a word. NO, use the C4 vette rear end for a custom IRS set up. The C5 tranny is attached to the rear end.
Old Apr 25, 2003 | 07:22 AM
irocz8957's Avatar
i wouldnt mess with it, sounds like it would be alot of trouble, i would have to agree with beast go witha c4 out of a vette
14
Aug 11, 2015 12:03 PM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
cmsmith
Jul 10, 2015 07:19 PM
cmsmith
Jul 5, 2015 07:23 PM
