Burnout Problem
Old Mar 10, 2004 | 05:55 PM
Ville H. Valo's Avatar
Burnout Problem
OK, i pop the clutch some times and the tires dont spin, the clutch just burns up. Now what do you think the problem is, could it be the hydralic clutch assembly or maybe i just need a new clutch. on rare occations, this has happened 3 times in 4 months, i have been driving the car hard and i will push in the clutch to stop at a stop sign or light and when i engage in 1st the clutch doesnt grab, the rpms just keep going up, so i have to stop for a minute and the the car engages again. WTF is going on?!?!?! Any input would be great.
-Ville
Old Mar 10, 2004 | 06:00 PM
NOTE: it doesnt engage in any gear.
-Ville
Old Mar 10, 2004 | 06:31 PM
TheGreatJ's Avatar
Sounds like the clutch disc is burnt up/worn out. You'll need a new one, and why replace when you can upgrade? I went to a SPEC stage 3 and LOVE it. Just be careful...if you get too good a clutch and too much traction you'll grenade that T-5.
Old Mar 10, 2004 | 06:34 PM
chevyman502bb's Avatar
let the T5 fry, once it goes u can always go T-56
Old Mar 10, 2004 | 06:37 PM
The clutch is from 2001... And it wasn't driven hard. And i was leaning towards the hydralic assembly because it just stops engaging somtimes. when a clutch goes out, isnt that the end of it?
Old Mar 10, 2004 | 06:44 PM
TheGreatJ's Avatar
A clutch, when it first begins to have problems, will generally engage fine when it's cold and get progressively worse as the friction disc heats up. It's evry possible that it's a hydro problem, but it sounds to me like a bad clutch.
AS far as blowing up the T-5 and then ditching it for a T-56...............that's what happened to my old 700-R4.
Old Mar 10, 2004 | 08:02 PM
Rice Killer87's Avatar
Re: Burnout Problem
-Ville
then u say...
lets make up ur mind 1st lol
have u checked the clutch fluid?
Old Mar 11, 2004 | 12:43 AM
i have only had the car for 5 months, sorry for the mix up.
Old Mar 11, 2004 | 02:52 PM
IROC-T's Avatar
Could be a weak pressure plate also.
NewsBot
Mar 30, 2015 11:31 AM
StreetDriven
Mar 15, 2015 07:12 PM
blac94Z
Mar 6, 2015 07:55 AM
CARiD
Dec 26, 2014 04:20 AM
94foormula
Sep 6, 2002 10:53 AM
