a bolt missing in the tpi runner to lower intake..
Old Jul 11, 2005 | 10:20 PM
LoudmouthSS's Avatar
IS this going to cause any problems?...its the bolt thats like right next to a fuel injector...i lost it and now i cant even put it in even if i found it..unless i ripped everything apart again..but will this cause any problems?
Old Jul 11, 2005 | 11:48 PM
fade2blk500's Avatar
Re: a bolt missing in the tpi runner to lower intake..
You can try it but if you have any vacuum leaks you know why If it were me I would have got a bolt for it just to be safe.
Old Jul 12, 2005 | 09:42 AM
Tru2Chevy's Avatar
Yea, I would be worried about vacumm leaks with missing intake bolts.
- Justin
Old Jul 12, 2005 | 11:14 AM
**** lol......ok ill try to find a way to get it in
Old Jul 12, 2005 | 02:29 PM
91-Z28-L98's Avatar
If its not one of the bolts that attach from the back of the runners (underneath the plenum) then you should be able to get to it with everything attached. You might have to move some wiring around, but thats it.
Old Jul 12, 2005 | 04:33 PM
the top intake is on now...so idk if i could get it from the back...but if i unplug the wire to the injector...i might have enough room to get it on
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
HectorM52
Jan 31, 2015 07:29 PM
rcajun86
Jan 30, 2015 01:56 PM
