The best way to tell a 400
Old Jun 13, 2002 | 11:43 AM
IgorT.455/406's Avatar
Post The best way to tell a 400
Hey guys. I am thinking of building a new bottom end for my '88, was wondering what is the easiest way to tell a 400 sbc at a junkyard appart from other SBC stuff. What years and what vehicles did they come in. Thanks.
1981 Olds Delta 88 455/th400/3.23 posi
1988 Trans Am WS6, 355/T5/3.27 posi; RPM heads and Intake; Crane Fireball cam; Holley 750 carb; soon Comp RXE294H; th350 & 10" converter.
1994 Trans Am LT1/T56, no cat; Hooker CB; Hotch. SFC and STB; Ripper shifter; Poly mount; Lakewood LCA; K&N FIPK; Hypertech Airfoil; soon to port&polish MAF; Sprint springs & Bilstein shocks; GM Motive 4.10; Hypertech PowerTuner III
Old Jun 13, 2002 | 01:15 PM
angel71rs's Avatar
Post
It will be set off to the side, cause the yard owner already spotted it as a 400 as is asking buxx for it! j/k
400 balancer is not complete all the way around, it has a scalloped section. 3 freeze plugs on side of block (or 2 and a raised section in the middle for a 3rd). Casting #509 is a common one for 400's, but not the only one. check out mortec.com for a complete listing of casting #'s.
Old Jun 13, 2002 | 04:38 PM
Scott_92RS's Avatar
Post
Yea, what he said, and look for a 2 bolt block, the 4 bolt blocks were weaker.
Old Jun 14, 2002 | 04:43 PM
IROC&ROLL2
Guest
Posts: n/a
Post
The center 2 cylinders on each side are siamesed.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
Kawi
Sep 28, 2015 09:01 AM
Z Power
Sep 19, 2015 11:19 PM
