best L98 nitrous cam
Old Apr 4, 2010 | 10:44 PM
tgates's Avatar
I need to get a cam for my 91 camaro 5.7, i have mild bolt ons and a full exhaust, im putting a 100 shot in it, i need to get a cam that would go good with the nitrous and great without it. im keeping stock heads and tpi system
it will only be sprayed only a few times a season.
my mods-
headers / mid pipe
Exhaust cut out
True ram air system
Throttle body air foil
Adjustable fuel pressure regulator
Ported intake
Complete MSD ignition system,
cap, rotor, coil, 8.5mm wires, plugs,
Jet stage 2 performance chip
Underdrive pulley system (BBK)
27Lb injectors
Old Apr 6, 2010 | 03:37 AM
onefastgta's Avatar
For a 100 shot you won't know the difference in a nitrous cam. Cam it like you would for N/A and don't worry about the bottle. Stick with a cam within the stock powerband if you are using stock heads and intake.
Old Apr 6, 2010 | 06:59 PM
AutoRoc's Avatar
Maybe try an LT4 cam and 1.6 rockers? Might need better valvesprings, not sure..
Not the LT4 Hotcam, just the LT4 cam..
Every engine should have a 100 shot. The world would be all smiles... haha
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MadMav
May 25, 2015 09:35 PM
bandit383lt4
Dec 21, 2014 09:12 PM
