Backfires......
Old Nov 25, 2008 | 08:24 PM
marolife's Avatar
Backfires......
I'm working on my brothers '90 Iroc, trying to fix the backfiring problem it has. It backfires during deceleration through the exhaust @ like 3,000 rpm and higher. Any ideas @ what the problem can be? Any suggestions? I've already checked the timing, valves, timing chain,(all were good) and are in need of help. Thanks....
Old Nov 26, 2008 | 06:42 AM
86camaro383's Avatar
is it running rich?
Old Nov 26, 2008 | 04:15 PM
marolife's Avatar
I haven't checked that. Any ideas on how to check if it is running rich? Thanks
Old Nov 26, 2008 | 05:50 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
All the plug wires are good, and they're on the right plugs?
Perhaps one of the injectors is bad? Do an ohms test on each injector. They should be greater than 12 ohms, preferably 16 ohms.
Old Dec 1, 2008 | 07:50 AM
1987IROC350's Avatar
Mine backfired until I got an adjustable fuel pressure reg. Fixed it up good but I may have been a rare case. Hard to believe fuel pressure would matter.
