Auburn or zexel torsen, which is better?
I have a good chance at either gettting a posi unit off a 97 Firbird transam which has the 3.42 gear or getting the zexel torsen from SLP. Which would be the better route and why? The motor I am putting in my car will push over 300+ HP and an automatic.
zrs im glad i caught u first. i was in the same predicament you are. i was gonna get the same differential from slp that you where. i found a better place i got 3.73 gears a heavy duty eaton posi rebuild kit soild spacer and aluminum cover for 800$ let me know if your intrested in this ill give you the number to call
Jul 17, 2015 02:47 PM
