To Anyone Who Says Their Camaro Has No Rust!
Old Dec 1, 2002 | 03:01 AM
stonedchihuahua's Avatar
Yeah so anyways anyone who says their camaro has no rust may want to pull off the fender... look on the firewall in the corner where the floor boards meet... I found lots of rust there... also check under your ground effects (no rust car had big holes rusted through in places) oh yeah also if you are really curios look in the rear wheel wells... just thought I would come on here to depress people..
Old Dec 1, 2002 | 03:39 PM
Marc 85Z28's Avatar
No rust here - and I drive it everyday, rain or snow!
Old Dec 2, 2002 | 08:54 AM
Jim85IROC's Avatar
If you don't find any rust in those spots, check the bottom-side of the lower radiator support. I can't recall seeing a thirdgen or a 4-th gen without rust there. My friend's 99 SS had rust there when it had under a thousand miles on it.
Old Dec 2, 2002 | 11:23 AM
fbird95's Avatar
Some of thes spots people are claiming no rust on, are rusty at the dealer ship new. They rust in the waiting lot outside before they were shipped to the dealers. So i dont buy a Zero Rust Car one bit.
Old Dec 2, 2002 | 02:08 PM
Marc 85Z28's Avatar
Maybe you should see my car. The only spot that ever rusted on my car was the battery tray due to a leaking battery, and that has since been cut out and replaced. I picked my car apart last year when it got painted, and there is no rust!
Old Dec 2, 2002 | 03:37 PM
by the time I am done there better not be any rust on my car... I am cutting out any that I can't grind off... I will feel alot beter when it is done
Old Dec 2, 2002 | 04:20 PM
Jim85IROC's Avatar
You don't want to use a grinder to remove rust. You'll be bitterly disappointed a year later when all of the spots come back. Grinding does not remove 100% of the rust, even if it looks like it's gone. You need to sand blast.
Old Dec 2, 2002 | 05:40 PM
Chris Ja's Avatar
Eternal Member
Every car has some rust on it . The bolts or suspension rear diff ect. I can say my car has very little because I got it when it was new and has been garaged every winter and not driven in rain but a few times.. But if you wash a car it is going to get rust on it.
Old Dec 3, 2002 | 09:25 AM
CODY BEHNKE's Avatar
My buddy has a mint looking 90 IROC, We thought it had no rust until we took the right side groubd effect off.
Old Dec 3, 2002 | 06:56 PM
Yeah thats what it was like after I pulled all the dents on my car... I said to myself... **** I am almost done this thing and there isn't a bit of rust... I then took of the ground effects... as a result the car still isnt' finished being cleaned up and I don't have the time
Old Dec 4, 2002 | 02:17 AM
chesee48's Avatar
yea, everyone has rust somewhere on the car...impossible unless it isnt driven and stored in a show room =)
Old Dec 4, 2002 | 08:57 AM
tigersZ's Avatar
Has anyone tried to take off the ground efx's on an 1984 Z-28? I need to do it but I am not sure if the bolts that are holding it on will be able to be taken off. Is there a special tool that is needed or can I just use regular sockets or a wrench? Thanks. I would say that I have no rust but if I did that then I would be lieing and as I have been told in the past "Liers go to HELL." Thanks for your help
Old Dec 4, 2002 | 11:19 PM
fbird95's Avatar
Funny how no one bad mouths All the other posts agreeing with the fact the a rust-free car is new impossible.
Old Dec 5, 2002 | 06:30 PM
It is as simple as using a normal socket to get them off... the side moldings you need to take the emblem out of first and then unscrew them from the top and behind where the emblem was... you then lift and take it off..
Old Dec 6, 2002 | 12:17 PM
IROC5.7TPI's Avatar
My car has only seen 3 michigan winters, but it wasn't driven, it was just parked outside in the cold. It had rust in all the mentioned areas, plus in the t-top bracket in the center of the roof. It was the worse in the floor where the front left framerail meets the trans tunnel. I still have to repair the floor, but that should also be done this winter.
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
Sandersen511
Jan 13, 2015 03:49 PM
smokin25th
Jan 1, 2015 09:06 AM
CaRParts102
Dec 6, 2014 08:45 AM
Lederman1976
Nov 30, 2014 05:21 AM
