Anyone ever used dry ice on there intake?
Old Aug 3, 2002 | 02:43 PM
91RS5speed's Avatar
Post Anyone ever used dry ice on there intake?
Just curious if anyone has. Anyone ever though of this would it be a bad thing? I know with dry ice you dont have worry about liquid since it evaporates. Any thoughs would b good thanks.
91 RS Camaro 5-speed black w/t-tops 305 TBI now TPI
MODS: SLP cold air intake w/K&N, air foil,Accel 19 LB injectors, March aluminum under drive pullies, Alburn pro posi, Aluminum drive shaft, Random Technology 3'' cat-back, 8.5mm MSD wires, 160 thermo, jet fan swich, Custom chip with 91 vette computer, SSBC slotted rotors, optima battery in the rear, BMR adjustable lower control arms and panhard rod, Kenny Brown strut tower brace, TB bypass, no egr, no air
Old Aug 3, 2002 | 07:03 PM
Irocvette355's Avatar
Post
Yeah I've thought of the same thing.
I was thinking about getting a cool can from summit, and running my fuel through it with the dry ice. And like you said no mess!
Probably would work well...
1989 IROC-Z 355 M5
13.0@104
MACC All Camaro Show-
1st Place
3rd Gen Modified
1988 Chevrolet K-5 Blazer
6000 lbs. of a real SUV
2001 Yamaha Raptor
92 mph on radar!
Old Aug 4, 2002 | 10:39 AM
Z28ROC's Avatar
Post
I tried it on my LT1 at the track. I crushed it up and wrapped it in a towel. During runs, I'd put it in the frezzer of my RV. So it lasted all day. Did it help? No, I noticed no increase in ET or MPH.
That's not to say it won't work for you. But If I was gonna ice my intake again I'd sure use dry ice. Much less mess, and lasts way longer.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Old Aug 4, 2002 | 12:24 PM
Stephen 87 IROC's Avatar
Post
Unless you're in a heads up race where every bit of HP gained could help you win, I don't think the added expense and trouble is worth it.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.617
Member of the Calgary Drag Racing Association
Old Aug 5, 2002 | 01:01 AM
Garett92Z's Avatar
Post
spray the intake down with a small fire extinguisher... hella-cold :P
Old Aug 5, 2002 | 07:49 AM
Jim85IROC's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by Irocvette355:
</font>
Unless you're carburated, that's not going to help anything. The only reason to keep your fuel cool is to prevent vapor lock that happens when the fuel boils in the line. Hot fuel isn't going to make a difference in the motor. On fuel injected cars, the fuel pressure is high enough that the fuel won't boil.
The IROC Homepage
View the Restoration of an 85 IROC
Weekend projects aren't.
Old Aug 5, 2002 | 10:25 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
</font>
True to that...
1989 IROC-Z 355 M5
13.0@104
1st Place
3rd Gen Modified
2001 Yamaha Raptor
92 mph on radar!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Apr 3, 2015 10:54 AM
maybe2fast
Mar 26, 2015 08:34 AM
