Antenna Motor
Old Oct 4, 2003 | 05:33 PM
buzz12586's Avatar
Antenna Motor
The antenne motor on my 88 Camaro won't pull down the antenne anymore instead it just sits there and runs. So I pulled the accessory fuse and that stopped it but that also means I can't use my radio, PDLs or interior lights. Is there a place where I can just disconnect the motor. I have no problem just leaving the antenne up.
Old Oct 5, 2003 | 08:39 AM
Ucantcme57's Avatar
I'm just guessing but I think you could take out the inner fender and just cut both the black and the red wires, there might also be a blue. Tape them up or something to stop them from shorting out..
Old Oct 5, 2003 | 08:18 PM
krazzycowgirl's Avatar
88-90 Antenna Power fender mount G7748 169.95
www.classicindustries.com
Old Oct 6, 2003 | 12:46 AM
IROC-T's Avatar
Plug.....
There is a plug under the dash passenger side ,you have to drop the pannel like you would itf you were tring to remove the computer. It is a flat plug with three wires,I cut the middle one and wired a switch so I can turn the antenna off in the up ,or down possion. You may be able to fix the antenna by taking it apart an there is what looks like weed- wacker line going to the bottom of the antenna that pushes it up,and pulls it down. This line useually breaks right at metal. It goes in a hole in the end and is crimped in place,I've repaired three of them this way. The hard part is removing the antenna from the car.
T.
siguy
Nov 27, 2014 10:07 AM
97_396_WS6
Aug 4, 2002 10:23 PM
Red97LT1
Aug 4, 2002 08:01 PM
$hawn
Aug 3, 2002 04:59 AM
