Alternator Noise
Old Jul 2, 2004 | 11:27 AM
Tom87IROC's Avatar
Alternator Noise
Started the car up today and heard a clunking noise. Lifted the hood and discovered the noise seems to be coming from my 10yr old rebuilt alternator. Does this sound like bearings? I thought bearings squealed when they were going bad. Volts are holding fine. Temp guage is OK. A/C compressor not on. Anyone have an idea? Does my alternator need a new rebuild?
Old Jul 2, 2004 | 05:49 PM
Tom87IROC's Avatar
Correction. Volts sre NOT holding steady. The needle seems to jump everytime I hear the clunking sound. Volts are sitting dead even at 13 volts instead of normal 14. I just need a confirmation on what I suspect I already know.
Thanks.
Old Jul 2, 2004 | 06:08 PM
greezemonkey's Avatar
You could listen to the alternator real close if you put a extension or piece of wood up to it and put your ear on the other end. with the volts lowering I`d say you nailed it...can`t say it owes you anything.... going ten yr`s and all.
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
