All show NO GO !
Old Apr 14, 2003 | 08:43 AM
Blackbob's Avatar
All show NO GO !
Ok here's my problem I got a 91" RS 305 5spd. Yeah it's a cool project car and all comming along fairly well. BUt I can't seem to get it to start. But When it does start it wont stay running/ I have changed out the starter,fuel pump,map censor,fuel filters(both tank and chassie), and I still can't seem to get it to run corectly. I have tried just about everythign that i know of and still getting stumped anyone know what it could be ?
~Blackbob~
Old Apr 14, 2003 | 10:28 AM
irocz8957's Avatar
about how long will it stay running before is shuts off?
Old Apr 14, 2003 | 02:05 PM
krazzycowgirl's Avatar
If It doesnt stay running that long look at your MAF (if It has one) either that or Go down to your auto parts store & spend $300 for a Code Scaner (worth the money) & run the codes. If you go to http://www.angelfire.com/wa3/ivhorsepower/diag.html There is most of the codes.
Old Apr 14, 2003 | 02:41 PM
IROC5.7TPI's Avatar
It most likely is the coolant temp sensor located on the intake manifold or the thermostat housing. It has yellow and black wires going to it. They cost less than $10 and go bad over time, making the engine run pig rich and fouling out spark plugs and causing other driveability problems. It sometimes won't set a check engine light either.
Old Apr 14, 2003 | 02:45 PM
Chuck!'s Avatar
What all was done to the car?
Old Apr 15, 2003 | 11:36 AM
Drkhrse89's Avatar
No offense but I have to disagree with you on this one. I would spend nothing, unravel a paperclip and use that to read the codes. All you have to do is jump the upper right terminal along with the one to its left. You have to have the car in the on position but not started. The SES light will blink for a little bit. It will blink once then pause and then blink twice. It will do that 3 times and then if there is a code it will blink at different intervals. So if it is a code 33 it will flash three times pause and then three more times. Hopefully that makes sense.
Old Apr 15, 2003 | 12:32 PM
irocz8957's Avatar
i know you said you already replaced the fuel pump but it certainly sounds like thats the problem, you might want to check and make sure that you put in right!
Old Apr 19, 2003 | 11:39 PM
Blackbob's Avatar
Exclamation
Thanks guys,
WellI'll be sure to tell my friend since Im just posting his question for him. BUt anyway yeah hi uncle said there's a chance that the feul pump relays may be bad or something like that. But I don't think he has checked the coolent sensor or anything like that. I'll be sure to tell him too.
~Blackbob~
P.S
YEah he even went out and bought a scanner but it keps putting up completely different codes though.
Old Apr 22, 2003 | 08:14 PM
camaronewbie's Avatar
I disagree with the scanner too! $300 for something a paperclip gets for free? NO WAY! $300 is headers! $300 is heads! $300 is alot!
Old Apr 22, 2003 | 08:31 PM
doug791's Avatar
not if its canadian lol our money sucks
Old Apr 23, 2003 | 12:34 PM
Lungz's Avatar
I got a scanner for 15 bucks in the eastwood bargain box at englishtown swap meet, I never pass up those boxes again, best deal of my life.
Old Apr 23, 2003 | 02:42 PM
Sorry I would disagree with that too. you guys may have money to spend on headers, heads & stuff like that. But on my husbands car having that scanner saved us well over $6,000 on Shop bills because of it. I am sorry I dont trust back yard Mechanic of doing things. Dont get me wrong I know some great back yard Mechs & I trust them to look at my car. But come on Paperclip to read codes??????? I think not.
Old Apr 23, 2003 | 04:09 PM
Drkhrse89's Avatar
Have you tried it? That $.02 or what ever it cost "tool" has saved me a ton of money as well. I have been told by many mechanic friends to not waste my money on a scanner because it does the same thing as the paperclip. If you visit www.thirdgen.org you will read that a lot of people over there suggest it as well. In all honesty to each their own. I personally will continue using the paperclip because it works and has for many years without fail.
Old Apr 23, 2003 | 04:59 PM
white86TA's Avatar
what about timing? check that yet? i had that problem and my timing was WAAAYYY off
Old Apr 23, 2003 | 05:00 PM
Yes I have Talked to many ppl who have tired that & have also tried to the scanner. Most CAR ppl around here suggest the scanner.
As for TGO Yes I deal with them when I have to most guys there are rude & Try to force others to see their way about it.
We have own our scanner for 2yrs now & as I said it has saved up over $6000 in shop bills.
