Airdam Mounting Hardware, And a ?
Old Oct 23, 2004 | 03:37 PM
patRIOTik's Avatar
Hey, Just got my Air Dam in from GM parts direct (hopefully this piece will run cooler). The airdam looks fine, but doesnt have any mounting hardware. What size bolts will i need, and will this require anything i cant pick up at Ace hardware or someplace similar?
Also, Does anyone have the measurements for a stock Camaro (86 z28) radiator? Im ordering a flex-a-lite fan, and they need the radiator size. No, im not that lazy. My car is in the shop till wednesday getting all the suspension and buschings revamped, and I cant get into it with a tapemeasure until then.
Thanks all.
Old Oct 23, 2004 | 06:16 PM
Ben91RS's Avatar
Re: Airdam Mounting Hardware, And a ?
I ran into the same problem you did, no hardware! But, yes, you can get the bolts at any store that sells 'em. All you'll need are some short bolts with nuts, if I'm not mistaken, I'll go double-check for you.
EDIT: I just checked and this is exactly what I used: 5/16-18 X 1" bolts with nuts. You'll need six bolts and nuts. Hope this helps.
Old Oct 24, 2004 | 11:57 PM
patRIOTik's Avatar
Thanks mate, ill go grab some bolts of that size tomorrow
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
War Engine
Sep 18, 2015 07:28 PM
Daluchman1974
Sep 11, 2015 06:12 AM
