Air cleaner?
Old May 29, 2003 | 02:40 PM
Big_Z's Avatar
Air cleaner?
Ok, so the other day i was working on my car, and I noticed that it sounds really cool when I was driving around with the lid to the aircleaner off, the carburetor sounds cool I saw that edelbrock sells an air cleaner that is a little triangle, made out of mesh. I'd imagine that would allow the carburetor sound to travel out so i can hear it, eh? And is this a good value, it was only like 20 bucks, but are there better air cleaners that flow more air then that? Thanks!
Old May 29, 2003 | 06:14 PM
Damon's Avatar
Not a huge fan of those triangle shaped foam air cleaners. The foam never seems to last very long and they don't always fit a QJet carb very well. Try a commonly available 14x3" open element air cleaner with a 1.5" drop base. Cheap ones typically won't fit very well over a QJet (the acclerator pump arm hits the base) but a high quality one like Edelbrock or other companies sell will usually clear without spacers (and don't cost much more). Even if they don't you can stack up a few gaskets to get just enough clearance without hitting the hood.
And you'll hear those secondaries scream when you lay into it, just like they do with no lid.
Fatdog2
Feb 13, 2015 08:19 PM
SmokinZ28lt1
Feb 5, 2015 04:33 AM
95chwagon
Jan 13, 2015 09:19 PM
Collector Car
Jan 5, 2015 10:58 AM
stanghunter211
Aug 29, 2002 03:04 AM
