Are the accessory mounting holes the same on pre '87 and '87+ cyl. heads?
Old Jan 24, 2003 | 05:28 PM
My90Iroc's Avatar
Basically what is says, are the accessory mounts the same on both sets of heads? If so that would make the only differences the centerbolt and perimeter bolt valve cover setups and the angle of the middle bolts for the intake manifold right?
I want to know if I build a motor with the Stealth Ram could I get pre '87 heads and still mount my current serpentine accessory setup from my '90 motor? Thanks.
Old Jan 24, 2003 | 06:38 PM
jeffsbluez's Avatar
I HAVE ZZ4 HEADS (PRODUCTION L98 ALUMINUM CORVETTE) ON MY Z AND THE SAME BELT SYSTEM AS YOU AND I HAD ONE PROBLEM. ON THE PASSENGER SIDE THE BOLT CLOSEST TO THE WATER PUMP ON THE HEAD WOULD NOT LINE UP. I STILL DON'T HAVE A BOLT IN THAT HOLE AND HAVE SEEN NO PROBLEM WITH ANY WEAR HOPE THIS HELPED
Old Jan 24, 2003 | 06:44 PM
82355's Avatar
Wow, turn off the CAPS LOCK. Oh, and there is an e in Corvette.
Martin
HectorM52
Jul 30, 2017 11:46 AM
pimpss96
Feb 12, 2015 01:28 PM
MadMav
Feb 6, 2015 11:02 PM
rjc1629
Jan 27, 2015 10:46 AM
LS1 RULZ
Aug 13, 2002 05:40 AM
