Accel Intake Runners Superram
Old Aug 12, 2003 | 08:20 PM
shwine617's Avatar
Will the accel supperram runners fit on a stock tpi?
thanks
Old Aug 12, 2003 | 08:40 PM
Black6SpdTA's Avatar
Somebody told me that the stock TPI runners would work with a Superram so I would imagine Superram runners would work on a stock TPI? Call Accel I'm sure they'll help you out.
-Rippin
Old Aug 12, 2003 | 09:03 PM
shwine617's Avatar
if these runners will fit the stock tpi, where can i get just the accel runners from?
thanks
Old Aug 12, 2003 | 09:14 PM
Geezer powered's Avatar
The runners used on the superram will not work on a stock tpi.The superram works on the stock manifold but thats the whole system.For just runners go with slp's runners.
Old Aug 13, 2003 | 12:57 AM
aklim's Avatar
I once had to get gaskets in the night for the superram base of mine. Got them from GM and found that there was a noticable difference as to the size of the ports. The GM ones were much smaller than the Accel SR base. And yes, the SR intake and plenum will fit the OEM base but you will be restricted there. If you are going to change something there, change the TB, Intake Manifold, the Plenum and Runners.
Old Aug 13, 2003 | 01:01 AM
aklim's Avatar
SR Kit: http://www.lingenfelter.com/lingenfe...=16&pf%5Fid=40
Accel Runners: http://www.lingenfelter.com/lingenfe...=16&pf%5Fid=42
IMO, the runners are a waste of time. Get the kit or forget it.
dfarr67
Apr 10, 2015 07:44 PM
rcajun86
Jan 30, 2015 01:56 PM
CARiD
Jan 27, 2015 06:27 AM
95chwagon
Jan 13, 2015 09:19 PM
super83Z
Jul 11, 2002 10:16 PM
