ac delete
Old Apr 8, 2003 | 07:36 AM
irocz8957's Avatar
ac delete
i heard there was an a/c delete package you can buy, does anybody know where i can get that??
Old Apr 8, 2003 | 09:16 AM
LT1Powered85Z's Avatar
Just order an A/C Delete pulley (an idler pulley) from a dealer.
I don't know what you're talking about, regarding a "package."
Eric
Old Apr 8, 2003 | 09:18 AM
Lungz's Avatar
well thirdgenresource.com has packages but i think it's like 250 for EVERYTHING, you can normally get some of the parts off of ebay, the only part I am having trouble with is the driver side accesory mount for the power steering once the AC was removed i have like 3 brackets just to hold the power steering pump in, and I think it's like an 83-86 only bracket, if that you may also have trouble finding the HVAC, and I'm not sure, but there may also be an issue with the fan inside the AC delete box.
Old Apr 8, 2003 | 12:42 PM
irocz383's Avatar
This is what I did...
Go to a salvage yard and pick up a air box a blower motor from a non AC F-Body.
For the compressor / power steering bracket, I just cut the the top part off (were the AC would have bolted up to) and also cut the back part of the bracket were the second header bolt is. Then welded the two brackets together. I'll try to get a picture up this week sometime.
stylin99
Feb 3, 2016 02:24 PM
tnmotown
Aug 10, 2015 11:52 PM
guest74777
Mar 25, 2015 10:30 AM
alex5366
Mar 8, 2015 11:32 AM
NVMYTA
Nov 23, 2002 06:04 PM
