92 camaro starting problem
Old Feb 22, 2004 | 09:34 AM
camaro9225th's Avatar
i have a problem starting my camaro 92 rs 305 tbi. is was working fine today and now it does nothing. the starter will not engage from the key. if you cross the solinoid it will spin. i noticed before this happened that it was having me click the key a couple of time for it to start. i think i was my shifter connection. if i move the shifter it would click and sometimes not.<b&m rachet> now it willnt do anything no noise or anything. everything is working fine and it was ok like an hour before i just turned it off and came back and nothing now.. anything can help me guys thanks
Old Feb 22, 2004 | 12:30 PM
Rice Killer87's Avatar
sounds like it could be the neutral safety switch since u said u had an aftermarket shifter. try to put it in neutral and start it instead of park...and maybe wiggle it around if it doesnt work.
Old Feb 22, 2004 | 01:44 PM
i figured that 2 but i just found out that i have no power going to the switch. so i dont know what the heck to do now.. what is before the switch to give it power.. broken wire? ing switch?
Old Feb 22, 2004 | 08:36 PM
841LE's Avatar
Maybe the ignition switch?Is the shifter completely in park,if not your car wont start .Try readjusting the shifter.
Old Feb 22, 2004 | 08:50 PM
greezemonkey's Avatar
Check the fusible links at the starter first to see if there is power after the links
Old Feb 23, 2004 | 08:13 AM
it has 3 wires and 2 links before the starter i know at the starter is has power. so it could be just 1 of the wires then....yeh its defenally in park soo... ill keep tring
Old Feb 23, 2004 | 02:25 PM
changed the ing switch and nothing yet
Old Feb 23, 2004 | 05:13 PM
841LE's Avatar
Is the Ing switch actuator rod connected at both ends.Can you tell if it slides back & forth when you turn the key.
Old Feb 23, 2004 | 05:15 PM
car has been towed to a shop cant wait around any longer i got to work so. thanks for the help though.. but yes it did move when u turn the key.. i can hear the relay click real loud when turning the key also. i thikn a fuseable link or wire is burnt threw somewere ..
Old Feb 23, 2004 | 05:31 PM
let us know the outcome.....sometimes it isn`t fesible to throw darts, it just pays to cough up the money for a pro sometimes
Old Feb 23, 2004 | 05:54 PM
unfortanally i agree this time.. as soon as she gets done i am gonna go do a mojar road toasting burnout..
Old Feb 24, 2004 | 08:42 PM
well they have found out that. the security relay went out again and that now it will start but the injecters will not pulse. so in return will not start but will turn over now. they now found something call a passkey module i believe. they said they have no ground and its being grounded threw the module. so they are looking for that part and i will know tomorrow if it runs.. i hope damn
Old Feb 24, 2004 | 09:52 PM
OH NO! I`ve never had to change one! make sure your not stuck buying it if they are wrong! Usaually the problem with a pass key system is right at the tumbler....pass key dosn`t use ground to verify that the right key is in the ignition, it uses a specific resistance between 100 and 1000 ohm`s The problem usaually is that one of the resistance wires break at the tumbler.....easy way to check is check resistance with a ohm meter at the end of the wire coming out of the column....it should read the same resistance as the "chip" in your key. Hope they know it`s not that!
Old Feb 26, 2004 | 06:33 AM
ok the car will turn over now from the key but now they said they aint getting injector pulse.. would the pass key make that happen.. this happened like 2 years ago and it was the securty relay.. which they said they replaced this time.. they said they have done 3 different test and they all point at the pass key mod.. the thing is once its in its mine..so if it doesnt work i am down 440 dollars and i just cant do that.... total bill at this time with pass key 720 dollars... i think its time to trade it in...
Old Feb 26, 2004 | 04:49 PM
dont get all down in the dumps man,u have to rememeber the car is 12 years old...over a decade. things are going to break and more than most of the time its expensive. dont give up on it
