91 drum brakes
Old Feb 11, 2004 | 09:55 AM
ryan80z's Avatar
91 drum brakes
i was re doing my drum brakes on my 91 s, and i couldnt get the wheel cylinder ring to lock in. what is the best way of doing this?
Old Feb 11, 2004 | 11:50 AM
dailydriver's Avatar
i did drum brakes on my blazer not too long ago. not exactly sure what yer referring to since it was only once ive seen a brake job, if it is the cap of the spring that has to turn into place once mounted then it just takes patience and a second tool to stabilize it while twisting it. Hope this helps.
Old Feb 11, 2004 | 06:04 PM
greezemonkey's Avatar
Usaully I have a friend hold a pry bar tween the axle flange and the wheel cyl to push the cylinder toward the backing plate...then with a screw driver I get one side to clip in then strike the screw driver handle with a hammer aganist the other side of the clip to seat the clip. They can be a challenge even for a pro
Old Feb 12, 2004 | 12:26 AM
ryan80z's Avatar
ya, ive tried the pry bar with a screw driver. ive also tried using a socket, but none of them seem to work, i guess ill just have to try harder, but i probably should have taken it off while i had the axel out due to the real axel seal
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
