91 camaro nitrous
Old Feb 21, 2007 | 03:28 AM
z28camaro095's Avatar
91 camaro nitrous
ok u might smack me but i was wondering about nitrous. i have a 91 z28 with a 335 stroker and a beefed up tranny and and beefed up rear end say i were to just go and buy and nitrous kit and installe it 100-150 shot would the car hold up and for how long? if so then in ur guys opinion which nitrous kit is the best? ty u for any info
Old Feb 21, 2007 | 08:59 AM
teke184's Avatar
try the nitrous forum
Old Feb 21, 2007 | 09:21 AM
2000GTP's Avatar
There is a sticky in the nitrous forum outlining the basic safety gear needed to safely spray. A 100-150 shot shouldn't be too out of line depending how wild of a setup you have right now with your motor. If you have a motor pushing some high numbers already, then you may want to consider a beefed up bottom end as well.
Old Feb 21, 2007 | 09:50 AM
Rice Killer87's Avatar
Do you have forged pistons? If not,your pushing it already.
With a good fuel system and the timing pulled correctly,it would be safe for a while as long as your not hot lapping at a 1/4 mile drag strip.
Old Feb 21, 2007 | 04:20 PM
AutoRoc's Avatar
If you don't know anything on the subject, do a lot of research on how the system works and why it does what it does. A 100 shot will be safe on any engine if it's tuned properly. A singe heat range colder spark plug, correct timing, consistant pressures are all going to lead to a good running combo on the spray.
If you're still TPI injected, I got away with an LT1 wet kit from nitrous express. Plumb the single nozzle into the engine side of the MAF aimed at the engine. Start with 75hp and work your way up. Goodluck!
Old Feb 23, 2007 | 11:51 AM
onefastgta's Avatar
Depends on what tranny you are using and what tires at the track also.
Any of the adjustable 100-175 hp kits will work fine. If you want more peace of mind, I would at a minimum get an rpm window switch(summit has a cheap one) and a bottle heater. You don't really need anything else. Follow the directions for the kit and spray away.
You will have a problem with traction though.
alphaauto
Jan 23, 2015 07:42 AM
Jrlt1
Jan 3, 2015 07:38 PM
bandit383lt4
Dec 21, 2014 09:12 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
