9 bolt, how much power can it take?
Old Jan 3, 2004 | 02:13 AM
Evil Turbo SS's Avatar
The GM/AUS 9 bolt is stronger than the 71/2 and the other larger 10 bolts but can it take the abuse that a 12 bolt, 9 inch or a dana60 ?
I am looking for a "roller" for a project car and I want to know if I should pass up the 9 bolt.
Old Jan 3, 2004 | 02:16 AM
97WS6SCharged's Avatar
I've heard that the 9 bolts are stronger than the 10 bolts that GM used in most of the 3rd gens, but I seriously doubt they will take the same abuse that a good 12 bolt or 9 inch will handle.
Old Jan 3, 2004 | 02:25 AM
Better than the larger 10 bolts used in the GNs?
Old Jan 3, 2004 | 02:28 AM
A true GN rearend? Doubtful. Those are pretty stout. What are you planning to do with the project car?
Old Jan 3, 2004 | 02:32 AM
Dirt Reynolds's Avatar
No. The 8.5" 10 bolts used in the GN and 2nd gen Camaro is quite a bit stronger than the 9-bolt which has a 7.75" ring gear. If properly prepped, an 8.5" 10 bolt is good into the 8's. Dave Hennigar ran well into the 8's for many years with an EFI/nitrous 406" in his '71 Camaro with a beefed stock 10 bolt.
My '77 has most of the tricks and mods to the stock 8.5" 10 bolt (spool, axles, girdle cover, welded tubes, c-clip eliminators, etc), and it has never given me even a hint of trouble.
Old Jan 3, 2004 | 02:35 AM
I miss my 77 Z28.
Old Jan 3, 2004 | 02:40 AM
Im looking to put a Nelson racing twin turbo "crate" motor in a 90-92 Camaro. Overdrive auto trans.17x9.5 and 17x11 Fiske wheels baer brakes suspention-kmember-subframe ect...
Old Jan 3, 2004 | 02:48 AM
Go ahead and invest in a 9 inch or 12 bolt.
Old Jan 3, 2004 | 06:43 AM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Ive read that the 9 bolts, are comparibaly strong to the Dana rears, but wont take as much as the 9 inch or 12 bolt.
Old Jan 3, 2004 | 12:54 PM
RobsWS6's Avatar
9 bolts will make a few 1.4 launches before blowing up. It'll probably do a season or two of 1.5s. Mine is in the 1.6 range and doesn't make a sound. Those numbers are from others with TTA's.
I'm sure with a trans brake it might not like it. I'm just foot braking it.
Old Jan 3, 2004 | 09:02 PM
91 GTA Ramair2's Avatar
There is nothing wrong with GM 10 Bolt 12" rear end's.
I got 2, there In my C-30's............. ............
The Dana/AMC20's Are Damn Tuff............
I've seen them behind 572's & 502'sin first and second gen's.......
They do have them in the coil Over for the F-body's and G-body's.......
there 12 Bolt 10" rear end's..........Very very Stout I have yet to see one come apart that wasn't Smached into a few Rock's and bolder's....................
Old Jan 3, 2004 | 09:06 PM
Talking
but I'm getting a 9" Moser for my 91GTA to put behind the 540Hp 406TBI.........
Old Jan 4, 2004 | 08:51 PM
Stephen 87 IROC's Avatar
I ran high 11's at 117 mph on mine with 3.27 gears. I switched to a beefed up 10 bolt for a better gear ratio selection after a couple of years then finally installed a 9" when I finally went to a transbrake.
http://www.difftechnics.com/9_bolt_home.html
Old Jan 4, 2004 | 09:38 PM
Talking well well and well wasn't this an interesting turn of events....
I still will stand behind The AMC20 Rear end Forever Ive seen them take insane HP & Torque + some Narly RPM's.......
and they still lived year's and year's ...............
Old Jan 6, 2004 | 05:31 PM
mrr23's Avatar
sofar my stock 1986 9 bolt with 3.27 has held up to 12.13 @112 and 359 rwhp and 539 rwtq using 150 n2o.
