89 Iroc running rough
Old May 18, 2008 | 06:59 PM
  #16
89_Irocz's Avatar
bump
Old May 19, 2008 | 06:21 PM
  #17
89_Irocz's Avatar
Update, I'm still have the same problem. But what i have figured out is that it maybe a weak fuelpump. I primed the fuel pimp by turning the key to on. I stuck a small screwdriver in the valve on the fuelrail. Hardy any gas came out. I tried starting the car, and same thing. I sprayed starting fluid in the trottlebody and she started right up but ran like crap and shut off. I had to use starting fluid again to get it started back. It has a new fuel filter on it, that was the first thing I tried.
Old May 19, 2008 | 07:37 PM
  #18
Angelis83LT's Avatar
a fuel pressure check would tell you if the pump is crappin out on you.
Old May 25, 2008 | 01:28 PM
  #19
Z28blake's Avatar
How much pressure should I have at the rail test port.
Old May 25, 2008 | 06:43 PM
  #20
I think it is supposed to be around 40-45psi
Old May 25, 2008 | 07:50 PM
  #21
Z28blake's Avatar
Can some confrim that B/C I only have 36# . Thanks
Old May 25, 2008 | 09:15 PM
  #22
I just did some checking on thirdgen.org.. looks to me that you fuel preassure is low. should be right around 40# avg with it idling and vacuum line off the regulator.
the spread is 43.5#-38# But most say 40# is where you would like it. looks like maybe your pump is not doing it anymore?
Old May 26, 2008 | 08:02 AM
  #23
Z28blake's Avatar
Thanks for the help , 89 iroc check your fuel pressure I may have found my problem .Sorry to hijack your post but when I logged on yesterday Your car is doing the samething as mine .You guys rock!
Old May 26, 2008 | 04:05 PM
  #24
89_Irocz's Avatar
thats cool you just helped confirm what my problem is.
Old May 26, 2008 | 05:38 PM
  #25
No problem.. all I do is read these forums and such.. Some things tend to stick
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
capebuf
Jan 13, 2015 07:22 PM
rockync7
Jan 1, 2015 05:10 AM
