'89 Intake To '88 Block: Questions Arise/56K Beware
3 Attachment(s)
Starting with the basic question. Will it work and what glaring differences will I run into? I went ahead with high resolution pics provided to ask the obvious.
I am taking small steps to ensure a trouble free installation with your help. In the pic below I possess a complete 1989 intake assembly. The 1989 ECM 01227165 is on the table. Does my 1988 IROC Z28 have the same ECM? I have no problems with the original ECM. The '88 came with a 305 LB9 TPI motor. Attachment 31798 I am presently cleaning the '89 intake manifold. I want to know the obvious differences I'll run into. I believe the only issue is the 9th Cold Start Injector. Anything else? This pic shows the front views of the '89 intake on the left and my '88 on the right. There is something missing I spotted hence the new thread. I guess I wont be using this electrical port. Need info. http://i116.photobucket.com/albums/o...8/DSC01124.jpg Intake Runners: Elimination of 9th Cold Start Injector. Attachment 31799 Fuel Rail & Regulator. There is no vacuum tube provision on the '89 fuel pressure regulator. Attachment 31800 So point me in the right direction, I need clarification here. I'll install the intake, fuel rail and plenum and hope it will start after priming the fuel pump rail. I think it's too easy with some missing items I guess I won't be dealing with. The '89 fuel pressure regulator looks like its adjustable than the vacuum assisted '88 FPR unit. What else should I be concerned about? ECM swap I figured due to the absence of the 9th injector. I want to install new injectors also. I don't know if I have Multec injectors or not. Whew...:think: |
Same ECM different program in the chip. I believe that sensor is for the Cold Start injector. 89 is a good tune keep use that chip. Is the 89 setup from a 305 car?
BTW that is not a factory FPR on the 89 rail. Definately aftermarket. |
the fuel injectors are better on the 88 than the 89
the 89 AFPR is supposed to have a vac nipple and will work on the 88. it just needs the vac nipple.
1 Attachment(s)
Originally Posted by super83Z
(Post 6019946)
Originally Posted by antoine
(Post 6023412)
Originally Posted by quickchicken
(Post 6023964)
Attachment 31609 |
You should reuse your injectors if there isn't anything wrong with them. Check the injectors on the 89 rail they might be to a 350. 350 had bigger injectors.
1 Attachment(s)
(Post 6024700)
Looks like I do have the 350 injectors omg. Far as I know the 305 block wont know correct? I mean these bigger injectors will be squirting inside the 305 bore along with the complete '89 intake. Injector on the right is the 1988 305 setup. I'm learning as we go... Attachment 31608 |
hmm with the 89 program and upgraded fuel injectors it'll be ready for some other mods.
the 350 uses a 22 lb injector and the 305 uses a 19 lb unit. im running a set of the SVO units and they work well, actualy its ben said they work better than the stock multi tech injectrs that came stock.
Rich at cruzin performance can service injectors but usually (IIRC) dosent do the multi tech units. me personally id go with a new set. FAST has matched sets and are within a reasonable range and i think the SVO's can be had thru summit or jegs. |
