88 iroc problems
Old Jan 9, 2005 | 06:55 AM
popcornchicken's Avatar
88 iroc problems
Heres a list of problems my 1988 camaro Iroc-z(5-speed) has.
-The motor lags majour power before 1500 rpm,
-The car tunrs off after taking out of gear after a long drive(freeway)
-NO POWER AT ALL when making a right turn(push pedal,nothign happens)
-Small but noticeable ticking noise coming from back of motor
Hopefully you guys can help me track down my problem, thansk for all yer help.
Old Jan 9, 2005 | 07:17 AM
V8Rumble's Avatar
Re: 88 iroc problems
OK (making an assumption that this is a TPI car), first question - have you checked for any codes that the car may have set? Getting a code can save you a good bit of time otherwise spent scratching your head...
The other question that comes to mind right away is 'How old are the "tune-up-type" things like fuel filter, plugs/wires, O2 sensor, etc?' Those can have a major impact on how your car runs...
Old Jan 9, 2005 | 08:47 AM
hmmmm... How do I Get the codes?My service engine light comes on but only sometimes. I know my fuel filter is new and my plugs and wires might not be to good, dont know bout o2 sensor.
Old Jan 9, 2005 | 09:34 AM
1981zzz's Avatar
if you go to a parts store some of them sell a code reader there not to expensive there worth the money, is there any black smoke coming out your exhaust when you are giving it gas i had o2 sensor go and the car ran rough and puffed black smoke,or like the other person said plugs and wires good luck hope you solve your problem
Old Jan 9, 2005 | 10:24 AM
V8Rumble's Avatar
Hit the link in my previous message - it's all explained right there...
Old Jan 9, 2005 | 12:25 PM
No black smoke. I think im gonan try the code stuff see what I can get out of that, thanks fer the help.
mark0006
Feb 28, 2015 07:12 PM
dale3in98
Feb 14, 2015 12:18 PM
dawg irocz
Feb 10, 2015 10:33 AM
capebuf
Jan 13, 2015 07:22 PM
