88 Iroc Convertible Detuned????
Old Nov 14, 2003 | 09:02 AM
gchu's Avatar
Why is the 305 TPI automatic in an 88 Iroc Convertible have such a lower rating (195 vs 220) than a 305 TPI automatic in non-convertibles?
What was changd? Is it just a change in chip to get it back to 220?
Old Nov 14, 2003 | 02:08 PM
Marc 85Z28's Avatar
Where are you getting the HP ratings from?
The difference between the 195HP 305 and 220HP 305 in 88 had to do with the manual trans/G92 optional gear ratio package. They got a more aggressive camshaft. The autos got the weaker "peanut" cam. That was the 25HP difference. The convertible option had nothing to do with it.
Goto http://www.thirdgen.org/newdesign/tech/techdb.shtml for more info...
Old Nov 14, 2003 | 03:23 PM
gchu's Avatar
Can I just change the Cam to pick up the missing 25hp or is there more to it?
Old Nov 14, 2003 | 03:27 PM
stanghunter211's Avatar
If you are going to change the cam, you might as well swap in some headers, 3" exhaust, and some other goodies while you are it. A cam is not a hard swap, but it is quite an undertaking none-the-less. And you can always add a nicer cam if you are looking for power. I think the 305 5spds just got the 350 TPI cam where as the 305 A4's got a totally different, weaker cam. Shop around.
Will
Old Nov 14, 2003 | 06:06 PM
Black6SpdTA's Avatar
I wouldn't simply get the stock cam, I'd go bigger--gain more power and have something to build on. Gonna need some power to move that 'vert!
-Rippin
Old Nov 15, 2003 | 06:27 PM
ChevyKen's Avatar
I put a Comp Cam, some WP 305 S/R Torquer heads, some SLP runners and a full Edelbrock exhaust etc. on my 305TPI 'vert, and it sure as heck woke it up Don't have any actual numbers, but the Desktop Dyno said roughly 290hp, but I do not know how close that is to the truth. It did make a major difference though!
Ken
gonzo275rltw
Jul 11, 2015 04:19 AM
mark0006
Feb 28, 2015 07:12 PM
dale3in98
Feb 14, 2015 12:18 PM
