im thinking of buying a 1987 iroc with 305 quad and borg warner t5.
i have a 91 z28 5.7 auto, and i want to swap the manual.
will the parts and trans fit my car(91) without problems?
im aware of the Torque rating and i plain to build the tranny to handle it before it goes in.
Yes the trans and all swap parts will fit just fine, only some minor fabrication will need to be done. FWIW in my 92 Ive had an 85 Iroc 5 speed behind a 95 truck 350 for 3 years and no problems so far. Although I do tend to baby the car.
Here is a short write up on the swap, not sure if you have seen it.
http://www.thirdgen.org/manualswap
http://www.austinthirdgen.org/index.php?pid=14
Another writeup on the T5 swap, with some pictures.
If you get all the necessary parts from the donor car (don't forget pedals, hydraulics, shifter plate and mainly the torque arm mount!), you should be ready to install it in one weekend. It requires just minor cutting in the floorboard (for the shifter) and the firewall (for the clutch master cylinder).
One last thing that will be hard to find is a chip for the T5 behind your 350, they didn't come stock that way so you'll have to find a home-made chip online and hope it runs well (it's always a gamble).
Hope this helps.
Lou
Hope this helps.
Lou
Quote:
The chip refers to the microchip in the computer that holds the tune for the engine.Originally Posted by tgates
thanks lou, btw what do you mean chip?? this is going to be my first swap lol
Don't plan on drag racing with a T5 unless you enjoy changing them.
Quote:
That does not apply to 3rd generation F-bodies.Originally Posted by Tex95Z
you will need to swap the trans crossmember from the donor car.
The crossmember is identical for the 700r4 or the T5 for his 1987.
Lou
the hard part will be hanging the pedals, mounting the reservoir and hooking up the hydraulics.
the rest is all simple nuts and bolt work.
Never heard of a chip failure when swapping to an auto, biggest issue is no torque converter which does not throw a code.
I know -- I swapped a T5 into my '90 L98.
oh yeah, dyno'd over 400lbs tq. Lots of runs down the track. T5 works great. Might want to get a poly bushing for the tranny mount.
