87 camaro
Old Apr 7, 2007 | 06:24 PM
HottestZ28's Avatar
87 camaro
My wife has my first car 1987 camaro 2.8. She loves it to dealth and its in great shape. Her father is giving me a nice streetable 350 cammed and 350 trans. I want to start on this project. First question is will 2.8 motor mounts work on the 350. second has anyone used the B & M 350 swap crossmember/torque arm mount? Third question will the stock driveshaft work? I want it to be a high 13 sec car when done- she wants to go racing with me.
Old Apr 7, 2007 | 06:31 PM
confused327's Avatar
the 2.8 mounts will not work.
the b&m th350 tq arm mount worked well for me.
i don't think the stock DS will work, mine did but i think only the '82 v6 ones did. a regular v8 DS will not work either, the th350 is an odd length.
Old Apr 8, 2007 | 09:25 AM
HottestZ28's Avatar
where did you end up getting motor mounts GM wants over 300 for the set.
Old Apr 8, 2007 | 09:49 AM
mdacton's Avatar
you can buy mounts from any auto parts place......They should be around $50 or less....
The b&m bracket works fine untill you get to the low 11's
Get a new DS made...money well spent...and I had the jegster DS loop...works very well
The motor mounts you just need the parts that bolt to the block...then the pc. that goes on the k-member is pretty cheap, I will check I may have some
Old Apr 8, 2007 | 02:19 PM
HottestZ28's Avatar
Ok thanks trying to just get the motor and trans in then start with all the little stuff
Old Apr 8, 2007 | 11:59 PM
I used a set of motor mounts from a '79 camaro. you can probably get some aftermarket ones from summit.
Old Apr 9, 2007 | 01:00 AM
xpndbl3's Avatar
autozone stocks the parts that bolt to the kmember for $15 a piece for motor mounts. The engine should still have its mounts on it
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
