86 Camaro - 26 spline rear?
Old Sep 24, 2003 | 08:05 PM
quickbiker's Avatar
I have an 86 Z28, 4bbl, 305, 5spd. Do I have a 26 spline rear? I know it's 3.23 ratio and open. I have a 2001 S-10 that I am putting a Detroit locker in, and I was thinking that I could put the stock Eaton posi from my S-10 in my 86 Camaro. But then it hit me, I think the early model 7.5's have 26 spline? If so, would a 28 spline shafts fit from a late model S-10? I could probably pick those up cheap at a junk yard if so.
Old Sep 24, 2003 | 08:32 PM
Black6SpdTA's Avatar
Yep, 26. They changed to 28 in ~89/90
-Rippin
Old Sep 24, 2003 | 08:45 PM
Dave89IROC's Avatar
Re: 86 Camaro - 26 spline rear?
probably not,l you just need axle shafts from a 90-92 camaro/firebird
89 was the changeover year, they could have either
Old Sep 24, 2003 | 10:01 PM
unvc92camarors's Avatar
correct me if i'm wrong, but i thought they switched over in 88?
Old Sep 25, 2003 | 07:33 AM
quickbiker's Avatar
Re: Re: 86 Camaro - 26 spline rear?
Yea, that makes sense, I will look for that at a junk yard! Thanks.
Old Sep 25, 2003 | 08:47 AM
aklim's Avatar
That's what I read too
Old Sep 25, 2003 | 11:52 AM
12Second3rdgen's Avatar
You will also need a carrier for 28 spline axles...
Old Sep 25, 2003 | 05:04 PM
Dave89IROC's Avatar
88 was the last full year of the 26 spline cars, 90 was the first full year of the 28 spline, in 89, it was a mid year running change
Old Sep 25, 2003 | 11:29 PM
Sitting Bull's Avatar
A lot of folks just go to Moser and buy their 28 spline axles for about $200. I think GM charges at least $300
Old Sep 26, 2003 | 12:17 PM
I got mine on ebay for $60.
Old Sep 28, 2003 | 08:42 PM
quickbiker's Avatar
One more question. Will the 7.5 ring gear fit on the 28 spline Eaton Carrier that had a 7.625 ring gear originally? I am guessing it should be the same ID on the ring gear and same holes?
ddr698
Jan 9, 2015 10:05 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
Dec 4, 2014 11:56 AM
siguy
Nov 27, 2014 10:07 AM
wytblur
Mar 2, 2003 03:40 PM
