85 camaro performance?
Old Apr 19, 2003 | 02:41 PM
americanmuscle1's Avatar
I am looking at a 1985 camaro f41 305 ho.... about how power are these putting down? What 1/4 mile times can u expect outta these cars? Also how hard is it to swap a bigger block in there... ex. 350 or 355 or maybe something bigger
thanks,
chris
Old Apr 19, 2003 | 07:41 PM
87DJP2001's Avatar
Look for a 350 car and you will save money in the long run.
Old Apr 19, 2003 | 08:14 PM
Black6SpdTA's Avatar
DJP's right, but puttin in a bigger motor isnt much of a problem if you dont get into somethin complicated (i.e. LT1/LS1/etc.) expect high 15 to low 16 passes w/ a stock LO3. good luck!
Old Apr 19, 2003 | 08:24 PM
stanghunter211's Avatar
LO3 is a 305 TBI, that 85 Should be an L69 if its an HO. Quarter times arent gonna be that impressive. Low 16's with 190 horses. Swap in a 350 block with that carb, better hanger, metering rods for the carb, and some tuning, should see a dramatic increase. Also you could invest in a better intake manifold , headers, all this stuff can be switched over to the 350 when the times comes. Good luck man. I had planned on this myself, but since my car got totalled, im looking at getting an L98 car......
Will
Old Apr 19, 2003 | 09:55 PM
oil pan 4's Avatar
85 power
On my 305 85 camaro with the 3.08 gears I could burn rubber through 2 second gear (auto) when staging.
They have some torque.
Old Apr 19, 2003 | 10:47 PM
Chris`s85Z28's Avatar
I have an 85 Z28 LG4 305 155 hp mine is a bit modded though I have headers and it`s cammed, timing is 13* I`ve beat a 5.0L and a 85 Z28 with it me and my friend timed it with a stop watch it ran .4km in 13.4 sec I can burn the tires in 1st and bark them in 2nd and 3rd
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Jan 11, 2015 06:10 PM
NewsBot
Dec 28, 2014 06:20 PM
NewsBot
Dec 3, 2014 12:30 PM
