82 camaro help!
Old Mar 9, 2007 | 12:38 PM
jacket4256's Avatar
82 camaro help!
I have a stripped out 82 camaro and I was wondering if anyone has a simple wiring diagram for the car its a street\strip so I took out everything that is not needed. just wondering if anyone done it from scratch b-4 bc I have no wires in the car at all. the next question is that I am putting a 400th in the car what do I need to get it to work since it had the metric tranny in it. Thanks for the help !
Old Mar 9, 2007 | 01:48 PM
Rice Killer87's Avatar
As far as wiring goes,I used a marine (boat) type fuse panel which is easy to wire up...all you do is put a power wire to the panel and run a wire from next to the fuse to the component your wiring's hot side,then ground the other side and it works perfectly.
As for the TH400 in a 3rd gen,places like www.bmrfabrication.com or www.spohn.net,maybe even summit racing or jegs might carry the crossmember you need.
Hope this helps.
Old Mar 9, 2007 | 04:23 PM
jacket4256's Avatar
where did you get the pannel and do you maybe have some pics of it thanks
F'n1996Z28SS
Aug 23, 2023 11:19 PM
CARiD
Jan 14, 2015 04:00 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
NewsBot
Dec 3, 2014 12:30 PM
