4 Fuel Injectors Offline!!! Help!!
Old Jan 9, 2003 | 02:56 PM
Forgotten28's Avatar
Unhappy 4 Fuel Injectors Offline!!! Help!!
Four fuel injectors are offline right now, all on the driver side. Guy at the shop doesn't know what he's doing. He first thought it was the MAF. It's not. Next, he thinks it's the computer chip (since it has a performance chip) but he's not sure. Anyone have a definitive answer? Please help!
1987 305 TPI Camaro
Old Jan 9, 2003 | 03:19 PM
Scott McDonald's Avatar
Sounds like a problem in your wiring harness - maybe a loose ground. Has your mechanic checked to see if there is power at the injectors? Have you had any work done on the car recently?
Old Jan 9, 2003 | 03:23 PM
No work done on the car lately. There's no voltage at the end connections. He initially thought it was a problem with the wiring harness too. They're looking for a lose ground now. I was looking for a solution which might have been a common problem in other IROCs. Is the firing sequential?
Old Jan 9, 2003 | 03:57 PM
91RS5speed's Avatar
No the fireing is batch. Check for loose connectors or damaged connectors.
Old Jan 9, 2003 | 04:36 PM
all connectors have been checked
Old Jan 9, 2003 | 08:08 PM
aklim's Avatar
There are 2 fuses in the car. Each one controls 1 bank of injectors. If the fuse is good and you trace it back to the ECM and it is still good, ie the is continuity in the wires from the ECM to the injector bank then your problem may lie in the injector drivers in the ECM
Willie's Avatar
I find it hard to believe no one knows this. Each bank of fuel injectors is powered by a fuse. So if one side isn't firing, one fuse is blown. They are marked INJ1 and INJ2.
Old Jan 9, 2003 | 08:50 PM
what if the fuses were checked and they're okay? Also, I heard that a bad pickup coil inside the distributor can be the cause. Any more opinions? I love my car and I don't have any other car to drive to work. Thanks for all your help.
Also, the ECM drivers were checked. The car was even replaced with a new comp with no change.
Old Jan 9, 2003 | 09:46 PM
91RS5speed's Avatar
take a meter to the fuse or just replace it you can always eye ball it
Old Jan 9, 2003 | 10:21 PM
TheGreatJ's Avatar
Sometimes a fuse will blow and you won't be able to tell by looking at it....replace them on principle. Besides, they're cheap. I'd bet one of them is blown and you just can't tell.
Old Jan 9, 2003 | 10:53 PM
aklim's Avatar
If the ECM is good then follow the wires from the harness to the injector and see if it is cut or pinched by something. Mine did the same thing and was traced to a blow fuse. Checked the wiring later and found that it was pinched and shorted by the valve cover.
Old Jan 10, 2003 | 12:07 AM
STAYBG's Avatar
ITS A FUSE I HAD THE SAME PROBLEM ONLY MINE WAS THE PASSENGER SIDE.
Old Jan 10, 2003 | 01:06 AM
stonedchihuahua's Avatar
Can I suggest plopping a carb on it?
Old Jan 10, 2003 | 07:03 AM
Was it a blown fuse?
Old Jan 10, 2003 | 09:23 AM
thanks for all the replies. I know the board shows me as a new member but I've been a member for a long time...I just forgot my old password.
Anyhow, I'll try the fuses this afternoon and let you all know what I find. The more I think about it the more I think it's a fuse...four injectors went from working to not working in less than a second.
