350 Tbi
Old Aug 11, 2005 | 11:14 AM
riphc06's Avatar
350 Tbi
how much power can you get out of a 350 TBI? is there a lot of mods and parts out there?
Old Aug 11, 2005 | 11:42 AM
87DJP2001's Avatar
Re: 350 Tbi
Is this a engine swap or a so called stock engine??
Old Aug 13, 2005 | 07:11 PM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: 350 Tbi
With stock 64 lb injectors for a 350 TBI ( stock 305 is 61 lbs ) you can get about 300 HP at the crank. With 72 lbs 454 TBI injectors, you can get about 350 HP. Keep in mind, the duration of the camshaft really affects the computer and makes it a royal pain in the butt to tune. The TBI computers, being speed density, are even more sensitive to camshaft duration than the TPI speed density computer.
Old Aug 13, 2005 | 10:03 PM
anthony714's Avatar
Re: 350 Tbi
you got all the mods any other engine has,,exhaust,heads,cams intakes,new throttle bodies,etc...so decent power is possible,maybe not tpi or port injected power but decent.also wynnjammer superchargers sells a real nice cheap kit(1500approx)for the 4.3 s10 tbi...i see know reason why that wouldnt fit your engine.holler at them..its a low psi kit,i think 6 psi but that will add 60-80 hp..nnot bad
Old Aug 14, 2005 | 08:28 PM
riphc06's Avatar
Re: 350 Tbi
its a swap from a 305 tbi
Old Aug 14, 2005 | 09:14 PM
cas0484's Avatar
Re: 350 Tbi
It depends on which motor you are starting with and whether you will be adding heads/cam or not. Most people swap over to the LO5 which still has the crappy swirl port heads and nets something around 205hp. I've also seen alot of people swap in L98's and the GMPP 350 HO vortec motor. Either way, you're gonna run into tuning problems with the TBI computer the more wild your set up is. Goodluck!
HAWG
Sep 25, 2015 11:41 AM
92_RS_305
Sep 8, 2015 07:47 PM
MDZ28
Sep 7, 2015 09:16 PM
Rittmeister
Aug 7, 2015 01:13 AM
