327 vs 355 vs 383 ???
Old Mar 29, 2003 | 05:04 PM
1984camaroz28's Avatar
Out of the three what whould be the best motor for drag racing
Old Mar 29, 2003 | 05:06 PM
angel71rs's Avatar
All 3 can make good hp, it's just easier with a 383. I use 400's now.
Old Mar 29, 2003 | 05:12 PM
i thought 327s where good cause they tured alot of rpms
Old Mar 29, 2003 | 05:22 PM
angel71rs's Avatar
With a shorter stroke, they rev easier than bigger engines, but don't make as much torque. I've run 327's, 350's and 400's, and can tell you, without a doubt, torque is good!
The mild 400 I just installed in my 71 pulls from off idle to 6,000 like no 327 ever could. And that's with a small hyd flat cam and smog heads. With a big cam, AFR heads, etc, it would probably pick up another 75-100 hp. The last 400 (very similar specs) ran a best of 13.7 at our local 4,100 ft track. About a 13 flat corrected to sea level. The car weighs 3550 with me in it, TH350, stock converter, 3.42 gears, Radial T/A's. Idles like a stocker, plenty of torque driving around town. No mild 327 could do that. It would have to be built, require a high stall converter, and deep gears.
There is a mystique surrounding the 327, but trust me, build the biggest engine you can afford.
Old Mar 29, 2003 | 05:27 PM
ZZ430RS's Avatar
Build the biggest engine you can, and put the best heads on it you can afford. It's a myth that 327's will out rev. a 350, but maybe a 383, but a 383 will still out power it.
Old Mar 29, 2003 | 05:50 PM
Ya i got a good set of 2.02 heads put for a 400 small block they will need stem holes driled how much will that cost me
Old Mar 30, 2003 | 08:16 AM
angel71rs's Avatar
No need to pay someone to do it. Just use the head gasket as a template to centerpunch the locations and drill out with a 1/8 bit and a hand drill. Just angle towards the water jackets, about 30 degrees, after you get drill bit started. Iron is soft and super easy to drill. About a 1/2 hour job.
Do a search on the subject here; it has been covered many times.
Old Mar 30, 2003 | 11:24 AM
I heared theres problems trying to keep a 400small block cool
Old Mar 30, 2003 | 02:33 PM
so what whould be my best bet to build 355 or 383 or 400
Old Mar 30, 2003 | 04:35 PM
angel71rs's Avatar
No prpblem at 30 over. My last 400 never got over 180 even when I was idling in a long line at the entrance to the drags waiting to get in for some thrashing. At the risk of sounding redundant, build the biggest engine you can afford. Only problem with 400's is finding a good block that will run at 30 over. If you can't find one, next best is a 383.
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
smoknta
Aug 27, 2015 05:07 PM
alphaauto
Jul 26, 2015 04:40 PM
