For 2K, How Fast Can I Go?
Old Feb 23, 2004 | 01:20 AM
Toms30th's Avatar
The car:
87 IROC 350
58,000 miles!!
Stock
The Money:
$2,000
The rules:
I have to drive it everyday
I have to pass smog
What would you do?
Old Feb 23, 2004 | 02:22 AM
SSnthe10s's Avatar
spray it
Old Feb 23, 2004 | 09:12 AM
12Second3rdgen's Avatar
I spent $2200 for the 350HO crate motor and that got me into the high 12's, you wouldnt be able to duplicate that with TPI smog legal tho . I would say buy a good set of forged pistons and connecting rods and put a serious dose of nitrous on it.
Actually... now that I think about it, have you looked at these kits:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2460959466
He sells the complete kits for like $2,500 ready to install with everything you need.
Old Feb 23, 2004 | 10:51 PM
Beast91GTA's Avatar
I also vote spray, however in my opinion I would gradually build it up and make run on motor. But spray is the quickest and probably the cheapest assuming you don't tear something up.
Old Feb 23, 2004 | 11:30 PM
kevin 2.8's Avatar
i dont like spray, i feel its cheating and cheap, its also not legal everywhere, and the power isnt there unless you flip a switch. then you have to refill it, and it may hurt your motor.
and i feel it doesnt mean your car is fast.
id rather take that 2 grand and buy a used s/c or do an agressive cam, heads, intake, and exhaust
Old Feb 24, 2004 | 12:36 AM
Not to get into a big debate, but the beauty part of nitrous is- yes you flip it on with a switch. You build a stout n/a motor and nitrous is the icing on the cake. Plus, you only have to worry about fragging your motor when you are using it- not doing a n/a burnout or getting on it n/a in town.
Old Feb 24, 2004 | 01:55 AM
SSnthe10s's Avatar
THEN FAWKING DO THAT!
why would u ask if u know what u wanna do.
Old Feb 24, 2004 | 02:15 AM
Toms30th's Avatar
Umm, he didn't start the thread...I did.
I'm leaning towards going the heads/cam/intake route. If I go with something like Vortec heads, and an LT4 cam, which intake would match (that still passes smog)?
Old Feb 24, 2004 | 03:01 AM
SSnthe10s's Avatar
oh so he did carry on
Old Feb 24, 2004 | 05:20 AM
kevin 2.8's Avatar
Old Feb 24, 2004 | 03:41 PM
Toms30th's Avatar
Originally posted by Mike86Z28
$2000 including labor, I would say ...... Gears, headers/exhaust and then see how much you have left to play with. You have to decide if you want to keep the TPI setup or go with something else (carb, Stealthram, Superram, etc.). If you keep the TPI you could always slap on some Runners and an Adj Fuel Press Reg and possibly get the Plenum ported.
Just some ideas
Being that it's an automatic, should I go with a T.C. instead of gears?
Old Feb 24, 2004 | 06:50 PM
kevin 2.8's Avatar
if your handy enough to do it all yourself, would make all the difference in the world. as you would have more to spend that would be saved from labour expenses and you could dremel youself a port job on the tpi inkae and headers and exhaust manifolds
Old Feb 25, 2004 | 02:16 PM
Jids's Avatar
id focus on the driveline. ie. tranny and rear , then do the motor...
TQ 2200-2500 stall convertor, shiftkit, 3.42 gears...
Then stuff like headers, catback, TB foil, roller tip rockers (if u dont wanna do a cam yet) , better intake by means of runners, ported plenum or LT1 intake swap......
some computer tuning, underdrive pulleys etc etc.....
reduce weight, ie. lightweight carpeting etc etc....
even some suspension bits.... SUBFRAME COnnectors!!!!!!!
start off small, then go big.....
Old Feb 25, 2004 | 02:28 PM
doug791's Avatar
LMAO this is all REALLY bad advice. Saying what the next mod is doesnt make sense unless you know what your goals are for the car.
Doing heads, cam and intake is a bad idea on a stock motor if youre going to use top quality parts and want to be pushing 500 hp then youll just blow the motor up.
if your goals for this car lay in the 350-400 fwhp range then you could do cam, intake and heads.
Also whats more important to you handling or 1/4 mile speed?
Its important to set goals on where the car is going to end up so you know what youre aiming for. Its also important to realize the weak points on your car.
While some trannys and rear ends seem to magically hold rediculous amounts of power i wouldnt trust my stock rear end (assuming its a 10 bolt add 50-75 hp for a 9 bolt) past 350 and the tranny in the 325-375 range.
So if you plan on making over 350 hp, id do tranny and rear end first. Theres a million different things that come into play but the most important thing is knowing what you want to do with the car.
Old Feb 25, 2004 | 03:51 PM
RedIrocZ-28's Avatar
Tom, I did cam, pistons, headers, convertor, full rebuild incl. .030 over bore and new bearings etc. for about $2000. I already had teh 3.73 gears from a previous accident so take that into account. I did run high 13's with the car though for $2000. I did all the work myself except the machineing of the block and decking of the heads. check sig for details.
